Axle nut stuck.
Old Nov 17, 2004 | 12:52 PM
hybrid1990crx's Avatar
Default Axle nut stuck.
Ok so last night I hit a deer, fucked up my fender and hood and i had to rip it apart so im starting my b16 swap at the same time. I poped out the axles and am trying to get off the axle nut but the hub keeps spinning, even with someone on the brakes. I went out and got an impact gun, and my compressor is all the way up to 120 psi and its a real puss. I think if it wasnt for the hub spinning i could get it off with a breaker bar.
Any sudjestions?
Old Nov 17, 2004 | 12:58 PM
91civicEX's Avatar
Default Re: Axle nut stuck. (hybrid1990crx)
put the car on the ground and put the wheel on. have someone step on the brakes so the car wont move. put a big breaker bar on the nut, has to be about 5 feet. and hang on it or jump on it till it comes off.
Old Nov 17, 2004 | 01:01 PM
drdisco69's Avatar
What kind of impact gun is it? A trick we use is to take some air tool oil, and fill up the gun until it's coming out of the air fitting, I mean FULL. Plug it up and wail away. Breaks stuff loose that wouldn't before.
Old Nov 17, 2004 | 01:11 PM
rioninja's Avatar
Try picking up a bottle of map gas, and put some heat on it.
It looks propane, except it comes in a yellow bottle.
Old Nov 17, 2004 | 01:23 PM
brandon w's Avatar
Default Re: Axle nut stuck. (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of impact gun is it? A trick we use is to take some air tool oil, and fill up the gun until it's coming out of the air fitting, I mean FULL. Plug it up and wail away. Breaks stuff loose that wouldn't before.</TD></TR></TABLE>
i use the oil trick all the time. i've amazed my friends and family alike with it. its a risk but i have put a screwdriver in the rotor vents and had the caliper hold the hub still to break the nut loose.
Old Nov 17, 2004 | 01:34 PM
Batoutahell's Avatar
You can also wedge a breaker bar between your wheel studs and the ground to keep the hub from spinning.
slowpokesi's Avatar
Default Re: Axle nut stuck. (brandon w)
put a screwdriver in the slot in between the breaks, then use a 1/2 drive breakover bar with a 5 foot extension,
Old Nov 17, 2004 | 01:37 PM
EJ2-Fluffy's Avatar
Default Re: Axle nut stuck. (slowpokesi)
Just get a long breaker bar and toss some muscle into it.
-Jon
Old Nov 17, 2004 | 01:38 PM
dr_latino999's Avatar
Combinations of those is how I got my nut from hell off -
1) Torch the bastard using a MAPP for about 3 minutes
2) Spray PB Blaster Liberally
3) Torch again
3a)While torching, have someone get in car and apply the brakes and put the car in gear. If working on the passenger side, put in 5th, if on drivers use reverse.
4) Attach socket, breaker bar, and a standard 3 foot extension that you would get from a floor jack and then proceed to push down as hard as humanly possible.
And this is how I got off the nuts even though the tabs had welded themselves down. Broke right through them
Old Nov 17, 2004 | 08:13 PM
regime's Avatar
ive busted breaker bars on mine
i use a torch and heat the hell out of the nut to expand it really fast then hit it wiht the bar. that normaly does the trick
torching for a long time will heat both the nut and the axle. so it wont help at all
Old Nov 17, 2004 | 08:32 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
i injured my elbow pretty badly when a 1/2 drive impact socket shattered with me hanging on a breaker bar. ive also had axle nuts that when they broke loose, chunks of the other mating surface tore out and was stuck to the back of nut. now i have a 3/4" slide bar and massive sockets for this purpose. if that wont do it, i remove the whole spindle.
Old Nov 17, 2004 | 09:06 PM
xci_ed6's Avatar
Default Re: (mike_belben@yahoo.com)
for my brothers talon I ended up using a 8ft. cheater bar. To do this I rolled the car into a wheel chock then had him stand on the brakes while i bunced on the bar. A very quick way is to slide a chisle into the vents on the rotor through the inspection hole on the caliper, but I dont believe that would hold as well as the former method.
Old Nov 17, 2004 | 09:18 PM
JDM_Powered's Avatar
Well if the nut is stuck i suggest torching the thing cuz the bolts on my buddys down pipe were tightend with an impact and they got stripped. We torched em and they came off easy, just make sure RIGHT after u light em to loosen them RIGHT after,...
Old Nov 17, 2004 | 09:37 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Axle nut stuck. (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">put the car on the ground and put the wheel on. have someone step on the brakes so the car wont move. put a big breaker bar on the nut, has to be about 5 feet. and hang on it or jump on it till it comes off.</TD></TR></TABLE>
Right on the money! I can have an axel nut off on only a few seconds this way without screwing around with any lubercants or heat. I had a hell of a time years ago before i knew how to do it, but once i did whats listed above its been every time!
davey5300
Nov 12, 2024 02:53 AM
butter99
21
Nov 27, 2008 09:00 PM
italstallion
Apr 20, 2006 11:10 PM
91-lsvtecsi
Suspension & Brakes
Oct 18, 2005 07:57 AM
6.5inCivic
33
Aug 6, 2002 11:45 AM
