ITR cluster install?
Wondering if anyone knows how to take out the pins from the cluster connectors in the back. Is there a certain tool to unhook the wires from the connnectors or do I push down on something on the inside. If anybody has a clue what I am talking about would help. Thanks.
Your plug is blue, there's a white piece you must remove first in order for the wires to come out. Push on the sides of the blue plug and in the middle to release the white thing. Take a safety pin and push from the front of the plug. What you are doing is pushing down a small hook inside the plug which releases the wire. Pull the wire as you push down the small hook. If you need a installation diagram let me know.
spooncivic1
Apr 5, 2006 07:53 PM
