JDM fuel rail vs non JDM and ECU differences
Old Nov 17, 2004 | 05:24 AM
Mugen Civic Type R's Avatar
Default JDM fuel rail vs non JDM and ECU differences
OK. i have a JDM B18 Spec R and i would like to know the differences it has with the injectors and Fuel pump compared to the exported versions o USA / Australia..
(This is a race built engine)
Also if there are any differences in the ECU program etc.
p.s. yes its a B18 not B18c - as stamped on the block
please help
Ads.
Old Nov 17, 2004 | 06:28 AM
Aquafina's Avatar
Default Re: JDM fuel rail vs non JDM and ECU differences (Mugen Civic Type R)
I'm not positive, but I believe that the injectors and fuel pump are the same. Same bore/stroke so they should be the same.
Just try some searching and you'll find something.
Old Nov 17, 2004 | 02:44 PM
Default Re: JDM fuel rail vs non JDM and ECU differences (Aquafina)
I have tried finding.
I found out the non JDM DC2R injectors are 240cc and the pump is 50psi.
Im sure the JDM version is different ?
and the ECU. Would the JDM version have the 180km/h cut off ?
Old Nov 17, 2004 | 02:58 PM
Aquafina's Avatar
It's more or less the same engine so why would the pump/ injectors be different? Common sense.
Old Nov 17, 2004 | 03:29 PM
DutchITR1689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Civic Type R &raquo;</TD></TR><TR><TD CLASS="quote">
and the ECU. Would the JDM version have the 180km/h cut off ?</TD></TR></TABLE>
That's one of the differences. And the exhaust manifold.
If you are in AUS, you should know the B18C7, that's about the same as the JDM engine.
The USDM B18C5 has a lower compression compared to the JDM/EURO/AUS spec.
pimpnpink
Honda S2000
Nov 11, 2008 08:40 AM
darkstar1440
Sep 28, 2006 08:37 PM
BuddyC
Apr 5, 2004 03:18 AM
shift6th
Honda S2000
Apr 4, 2004 07:32 PM
prelittlelude
Jan 9, 2004 11:47 AM
