Valve Springs???
Old Dec 27, 2001 | 10:40 AM
pregunta's Avatar
Default Valve Springs???
As far as changing the valve springs. I have a ls/vtec with gsr pistons int it and a slightly milled b18c1 head. I am planning on putting ITR cams in it and I want to change the valve springs. Is it better to change the gsr spring out for ITR springs or put in some stiffening springs?
Old Dec 27, 2001 | 02:48 PM
rioninja's Avatar
Default Re: Valve Springs??? (pregunta)
Most people agree that typer springs should be good for about 8500. If it was my car, i would go with them and maybe some ti retainers to play it safe.
Old Dec 27, 2001 | 02:51 PM
Spade's Avatar
Default Re: Valve Springs??? (RioNinja)
http://www.c-speedracing.com N/A build up.
Old Dec 28, 2001 | 08:18 PM
suzuki99's Avatar
when i rebuilt my gsr motor....i put the gsr intake springs on the exaust side and then i bought new type r intake springs for the intake.....it worked just fine....
Old Dec 29, 2001 | 10:59 AM
Max GSR's Avatar
Default Re: Valve Springs??? (suzuki99)
That's an excellent way to do it. In general you want the lightest spring pressure you can get away with for the cams and rpm's you're gonna run. The reason for running a little stiffer springs than stock is because the ITR cams are slightly more aggressive, but mainly you'll probably increase the redline and at 9000 rpm, you need slightly stiffer springs to get the valves back to "closed" position in a real hurry so you don't get "valve float".
boostedteg4dr
Sep 26, 2008 01:08 PM
hmongyaj87
Dec 19, 2007 03:19 AM
B HATCH
13
Sep 6, 2004 12:25 PM
McFly
Feb 12, 2003 08:27 PM
pregunta
Dec 27, 2001 02:46 PM
