itr rear lca on civic
Old Nov 16, 2004 | 09:03 PM
8o8da9speed's Avatar
Default itr rear lca on civic
Modified by 8o8da9speed at 11:32 AM 1/14/2005
Old Nov 16, 2004 | 09:05 PM
spankey167's Avatar
Default Re: itr rear lca on civic (8o8da9speed)
from my understanding, you just need the itr rear lower control arms and they should fit.
Old Nov 16, 2004 | 09:14 PM
_RevHardD15's Avatar
Default Re: itr rear lca on civic (spankey167)
The lca alone is all you need, all the traling arms are put in equal distances and such, you dont even need an alignment afterwards, its a very simple installation
Remove shock or at least pull the lca-shock bolt then unbolt the lca from the traling arm, and then from the rear crossmember pull it out, bolt up is the same in reverse
Old Nov 16, 2004 | 10:19 PM
Default Re: itr rear lca on civic (_RevHardD15)
wow thanks for the answer!
Old Nov 16, 2004 | 11:06 PM
=GAME='s Avatar
ITR lca is not compatible with civic or integra's shock. ITR shocks sits inside of the lca, and civic/integra's shocks are forked shapes. If you have ITR lca, youll need ITR shocks.
Old Nov 16, 2004 | 11:33 PM
drunknbass's Avatar
Default Re: itr rear lca on civic ([G][A][M][E])
i have some civic sir lca's which are the same as itr lcas. for sale. shoot me an offer their yours
Old Nov 17, 2004 | 03:25 AM
MasterKwan's Avatar
Default Re: itr rear lca on civic (drunknbass)
ITR LCA's are still available new from Acura. They're about $50 each and include the three bushings. They're about 2-3 inches too short for an EK.
Old Nov 17, 2004 | 05:33 AM
hatchdrvr's Avatar
Default Re: itr rear lca on civic (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">ITR LCA's are still available new from Acura. They're about $50 each and include the three bushings. They're about 2-3 inches too short for an EK. </TD></TR></TABLE>
If you read the post <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [G &raquo;</TD></TR><TR><TD CLASS="quote">[A][M][E]]ITR lca is not compatible with civic or integra's shock. ITR shocks sits inside of the lca, and civic/integra's shocks are forked shapes. If you have ITR lca, youll need ITR shocks.</TD></TR></TABLE>
if either of you bothered to read the original post, he's asking about Tein coilovers and LCA's for itr/eg6. not EK, and yes the struts are different, that's why he's asking about them because you have to change them to itr/eg6 rear LCA's for them to work
To answer the original question, yes they bolt up, I have them with my Tein coilovers on my hatch, no alignment problems and are actually stronger than stock LCA's, and no, all you will need will be the LCA's themselves.
Old Nov 17, 2004 | 02:13 PM
Default Re: itr rear lca on civic (hatchdrvr)
Old Nov 18, 2004 | 05:20 AM
MasterKwan's Avatar
That's the cost of the trailing arm, not the LCA.
http://www.acuraautomotiveparts.org/
Good prices.
ka-nife_
May 3, 2006 06:16 PM
nikolai.
Nov 10, 2003 03:54 PM
Shark Tank
Feb 16, 2003 05:06 PM
fuguman
Aug 27, 2002 02:04 PM
P()()RB@Y
May 23, 2002 06:17 AM
