OBD2 shell with an OBD1 motor HOW DO YOU CHECK THE ECU CODES?
I have all the wiring done for this but the motor isnt in the car yet, when i put it in am I going to use the plug that comes from the 96 civic to check the codes? OR do I need to wire in a service connector to the ecu like the obd 1 style? The motor is an obd1 gsr and the shell is a 96 civic dx. ~Thanks!~
check the codes as u would for obd2 by insertin ah wire or paper clip and count the flashes and problems email me wheredidwedoit@aol.com
The car is obd2 though so there wont be that plug to jump. My question is do I need to wire that plug to the ecu then wire a bulb for the cel on the ecu side??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe »</TD></TR><TR><TD CLASS="quote">The car is obd2 though so there wont be that plug to jump. My question is do I need to wire that plug to the ecu then wire a bulb for the cel on the ecu side??</TD></TR></TABLE>
No, it has it already. under the dash on the passenger side. It is pushed way up there some times.
blowme
Jun 29, 2005 04:58 PM
