where can i find installation instructions for a head unit?
Most of the time it shouldn't be too hard to figure out.
If you look behind the console you might find nuts holding the deck in. Sometimes you have to pry off the area around the deck which contains the deck support. Generally if the console's width is just a tad wider than the deck's it's being held by screws in the back.
How about for an integra?? Something's loose, and needs to be tightened, but I can figure out how the hell to remove it! 3rd gen... TIA
Is this for stock unit? Two nuts in the back. Just shine a light there and you'll see them.
If it's aftermarket, most likely it's in a sleeve and you'll need a DIN tool to get it out. Or you can use two long flat objects (metal rulers work). Wedge it in between the HU and sleeve on the ends and slide the HU out. If the HU was installed with a kit check the back for nuts.
It was stock but this is aftermarket, with a kit, I looked in the back and couldn't see anything, do I have to take that part of the interior apart?? I hope not.
Edit: All I need to do is take it out and switch some wires.....
[Modified by SoCal ITR, 12:20 PM 1/12/2002]
DC2_Integra
Audio / Security / Video
Nov 30, 2002 10:36 PM
