nitrous question
Old Nov 16, 2004 | 07:39 PM
RedRocketCRX's Avatar
Default nitrous question
i was planning on rebuilding my d16a6 with some p29 pistons everything else is going to stay stock. i did the calculations and the compression ratio would be around 11.3. i was just wondering if it would be safe to spray with that amount of ccompression?
Old Nov 16, 2004 | 07:45 PM
krazie1's Avatar
BANNED
Default Re: nitrous question (RedRocketCRX)
I have a 50 shot wet system in my build motor with compression at 11:8
and still no problem yet
Old Nov 16, 2004 | 07:47 PM
mrspeaker's Avatar
It should be safe as long as you take proper precautions
colder spark plugs
Retard the timing 2-3 degrees every 50shot
Use 93-94 octane
You're takin a risk everytime you use n2o no matter if the motor's built or not...
Old Nov 16, 2004 | 07:53 PM
krazie1's Avatar
BANNED
Default Re: nitrous question (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">It should be safe as long as you take proper precautions
colder spark plugs
Use 93-94 octane
You're takin a risk everytime you use n2o no matter if the motor's built or not...</TD></TR></TABLE>
I was just letting him know it was possible but u nailed it down to the bone
this guy is great to this section of H-T
Old Nov 16, 2004 | 07:54 PM
Default Re: nitrous question (krazie1)
what do you mean by colder spark plugs?
Old Nov 16, 2004 | 08:02 PM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRocketCRX &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by colder spark plugs?</TD></TR></TABLE>
Colder plugs have less heat and will help reduce detonation inside your motor..
NGK and ZEX make colder spark plugs..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>]
Thanks for the compliment..
Old Nov 16, 2004 | 08:04 PM
cool. thnx alot guys
99black_em1
Nov 16, 2012 05:14 PM
jnasty
Feb 2, 2007 02:44 PM
B-motor
Nov 8, 2006 09:18 PM
f1 vtec
May 2, 2004 11:59 AM
andlude
Apr 2, 2003 08:35 AM
