H22 help needed in accord
Old Nov 16, 2004 | 06:53 PM
forcedaccord95's Avatar
Default H22 help needed in accord
ok guys,
for all you guys who think people dont search, relax i already did that!! i have a 95 honda accord that i dropped a 2000 h22a4 in. i have been throwing a 12 cel, which is a EGR problem, i by passed it by making a aluminum plate and putting the egr valve on top and tightening. next i plugged the plug in and checked all vacum diagrams ( they are all correct). last i reset the computer and went out for a drive. it was great for two days and then today that BASTARD code is back!! does anyone have a wiring diagram for this swap and the egr? please help!!!
thanks
Old Nov 16, 2004 | 07:15 PM
v4lu3s's Avatar
RTFM
did you switcht the pins at the ecu fo the egr and o2 heater?
Old Nov 16, 2004 | 08:14 PM
SuperSlow's Avatar
Default Re: H22 help needed in accord (forcedaccord95)
re check your alum. plate. If it was not thick enough, or heavy enough guage, it probably has burned through.
Old Nov 17, 2004 | 04:54 AM
Default Re: H22 help needed in accord (SuperSlow)
yes switched the pins, and yes i used a thick enough plate
thanks
Old Nov 17, 2004 | 05:15 AM
Monkey Fing a Coconut's Avatar
next time search better....this is under the faq's...
https://honda-tech.com/zerothread?id=933645
D_CRX_Si
Mar 8, 2007 06:44 PM
forcedaccord95
Dec 20, 2004 08:37 AM
forcedaccord95
Nov 16, 2004 08:59 PM
