Can the radiator coollant be flushed by DIY
Old Nov 16, 2004 | 05:30 PM
LudeChild's Avatar
Default Can the radiator coollant be flushed by DIY
Just wondering is it poossible to flush the coolant urself like the tranny and engine oils.
Old Nov 16, 2004 | 06:08 PM
BlissSkr's Avatar
Default Re: Can the radiator coollant be flushed by DIY (LudeChild)
yes it is just get a big drain pan and open the (petcock) on the bottom of the radiator and the coolant will drain out if you cant find the petcock just pull the lower radiator hose although this way is messy. then just run clean hose water through the filler cap untill the fluid comes out clear at the bottom shut off water allow it all to drain. close the petcock and fill with antifreeze-water mix watch the level through the filler hole as bubbles of air with work there way to the top. when it looks about full start your car and let it warm up leave the filler cap off so air can escape also turn the heat on so air is flushed from the whole system. after letting your car run like this for about five minutes top off the fluid and your done.
Old Nov 16, 2004 | 06:18 PM
mathews's Avatar
Dont forget to change the coolant in the overflow tank as well. I think you can just take off the hose at the bottom of the tank, but don't quote me on that.
Old Nov 16, 2004 | 08:15 PM
five-0's Avatar
Default Re: Can the radiator coollant be flushed by DIY (Chase)
What does it take to remove and then re-install a freeze-plug?
Old Nov 18, 2004 | 07:00 AM
PRCLude98's Avatar
Is it pretty much the same process on all Preludes or do I have to do anything different if I'm doing it on a 5th gen?
Old Nov 18, 2004 | 10:48 AM
Jagan'92's Avatar
You can also install a flush kit... at Autozone or the like, it's basically a T fitting that installs in the heater return hose. You drain the coolant, cut the heater return hose, and install the fitting, which has a connector for the garden hose.
Then you can run the car with the hose on and the rad cap off, and the coolant will come out of the radiator cap. That's a backflush.
Old Nov 18, 2004 | 12:18 PM
devi1man's Avatar
Default Re: Can the radiator coollant be flushed by DIY (Jagan'92)
That works but fair warning, those plastic tees suck. They have left many stranded on the side of the road with a heater hose split in two.
Old Nov 18, 2004 | 05:55 PM
Eddiebx's Avatar
Default Re: Can the radiator coollant be flushed by DIY (devi1man)
thats why u get a spare section of heater hose and just put that T on there temporarily
you'd have to be stupid to run daily with that T in there,
Old Nov 19, 2004 | 06:03 AM
devi1man's Avatar
Default Re: Can the radiator coollant be flushed by DIY (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">thats why u get a spare section of heater hose and just put that T on there temporarily
you'd have to be stupid to run daily with that T in there, </TD></TR></TABLE>
you'd be suprised how many people drive around with what amounts to little more than a cheap plastic tee capped off with the equivilent of a two liter soda bottle cap holding their coolant in.
Old Nov 19, 2004 | 07:58 AM
Jagan'92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devi1man &raquo;</TD></TR><TR><TD CLASS="quote">
you'd be suprised how many people drive around with what amounts to little more than a cheap plastic tee capped off with the equivilent of a two liter soda bottle cap holding their coolant in.</TD></TR></TABLE>
I do that! Word. No seriously, my cooling system has some problems with rust or something. I flush it every month almost. So until I get that straight, I will continue to run with the T. I do have an extra hose in my trunk, and a gallon of coolant.
david90
Jun 10, 2021 07:42 PM
ej1love
10
Jul 21, 2009 11:22 AM
wld2rde
Feb 10, 2005 05:54 AM
dbailey
Nov 21, 2004 12:34 PM
drumsy
Sep 12, 2002 07:14 AM
