antenna hasnt worked since ive owned the car
Old Nov 16, 2004 | 02:50 PM
GOTNOS's Avatar
Default antenna hasnt worked since ive owned the car
if this was your problem what would u start to look at ? Is there a fuse for the 4thgen anttena somewhere?
Old Nov 16, 2004 | 02:53 PM
Prolink's Avatar
Default Re: antenna hasnt worked since ive owned the car (GOTNOS)
do you have a stock radio? If you do check the connector at the antenna motor.
Old Nov 16, 2004 | 02:58 PM
Daboi630's Avatar
does it stay up? does it even go up? or do you not receive any reception?
mine stopped going down. mine was fixed by purchasing an antenna mast from ebay.
GOTNOS's Avatar
Default Re: antenna hasnt worked since ive owned the car (Prolink)
naw i got a dual deck clarion cd and tape player, the antena doesnt even go up an di have no receptions.
Old Nov 16, 2004 | 03:00 PM
Daboi630's Avatar
can you hear the motor working?
Old Nov 16, 2004 | 04:20 PM
GOTNOS's Avatar
Default Re: (Daboi630)
its suppose to go up when the car starts right? if its supose to make a noise then nuthing is coming from the rear besides the fuel pump priming.
Old Nov 16, 2004 | 06:17 PM
Mr.Dew's Avatar
Yep, it's Eric.
Default Re: (GOTNOS)
theres a fuse that controls the antenna.. i can't remember if its under hood or dash though but it should say on one of the fuse panel covers. your mast or motor might be broken. and it should only go up when you turn the radio on.
Old Nov 16, 2004 | 07:07 PM
prelude1897's Avatar
Default Re: (oNeMoBB1)
maybe whenever the radio was hooked up, they forgot to hook up the antenna wire. I'd take the radio out, and make sure all the wires are hooked up right. The antenna wire is blue sometimes with a white strip, but if that isn't hooked up, then that is probably why your antenna isn't working
Old Nov 16, 2004 | 07:42 PM
LudaMan's Avatar
Look what I can do!
Default Re: (prelude1897)
im guessin they didnt connect the antenna wire. My antenna doesnt go all the way down anymore and makes this big RRRRRRRRRRR sound when it stops (very annoying) I'm thinkin about cutting the wire and capping it and leaving the antenna the way it is since i hardly ever listen to the radio anyway.
Old Nov 16, 2004 | 08:03 PM
five-0's Avatar
Default Re: (LudaMan)
HI-JACK:
Since we are on the antanae subject.... is there a way too manually control the motor. Sometimes I don't like it reachn' for the sky. I know of the JDM half-way switch. But JDM is $$$. How bout a toggle switch instead?
Sorry GOTNOS, here is your thread back.
Old Nov 16, 2004 | 09:13 PM
GOTNOS's Avatar
Default Re: (five-0)
lol i dont care if u jack this thread bro hehe my issues are getting attention thats all that matters to me. Ill check the fuse and the wire thanks.
Old Nov 16, 2004 | 09:33 PM
five-0's Avatar
Nevermind. SEARCH>ME. http://www.sandmracing.com/santennaswitch.html It looks quite simple.
Old Nov 16, 2004 | 09:46 PM
BrokeLude's Avatar
I just disconnected mine and put a window mounted flat one in the back window.
Old Nov 16, 2004 | 11:21 PM
esca's Avatar
Default Re: (BrokeLude)
SHAVE IT OFF!
but yeah.. if you dont hear the motor running.. check the fuse.. if fueses are fine it might be a wiring problem
if it does go up.. and gets like.. stuck half way.. buy a new one.. cuz its broke
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
b18_integra
Sep 22, 2007 02:14 PM
Darkray16
Apr 20, 2006 11:41 AM
geminis2k
Dec 1, 2003 10:53 PM
glock
Feb 1, 2002 09:36 PM
