how do you pull a CEL on OBD1 ????
Old Nov 16, 2004 | 02:23 PM
Squirtin EGsr
Guest
Posts: n/a
Default how do you pull a CEL on OBD1 ????
is it the same as OBD2 with the jump wire ??? using a OBD2 to OBD1 conversion harness.
Old Nov 16, 2004 | 04:09 PM
eda6's Avatar
Default Re: how do you pull a CEL on OBD1 ???? (RiceRocket12s)
Locate D4 at the ecu and ground it. Count flashes on the cluster.
Long flash=10 and short flash =1
There may be an easier way to do it. I converted from obd 0 to obd 1 and this is how i check mine. I'm too lazy to install a toggle switch.
bigtimlikewhoa
Nov 12, 2005 06:57 PM
anduknodis
Sep 18, 2004 11:54 AM
stevieteg
May 17, 2004 11:35 AM
onesikviet
Dec 8, 2003 06:12 PM
