LS/auto shifter issue.
Old Nov 16, 2004 | 01:44 PM
Feriofan's Avatar
Default LS/auto shifter issue.
I used the search option and cannot locate any info.
I’m trying to figure out an issue with an LS auto shifter (91 Integra LS).
The shifter will work just fine during the summer, but during the winter specially when the temperatures are low the shifter will get stuck when you change from (D) to reverse or (P). Is a big issue when you want to park the car, since if the shifter position in the dash does not light up on (P) position, it will not release the key!! Or if you need to maneuver it will not let you shift from (D) to (R ).
Anyone else had a similar issue and/or fix?? Or any ideas of what the issue could be?
Thanks
Old Nov 16, 2004 | 05:27 PM
lv6l's Avatar
when was the last time you change the transmission fluid
Old Nov 16, 2004 | 06:21 PM
whiteboy4life74's Avatar
Default Re: LS/auto shifter issue. (Feriofan)
Im having the same exact problem. during the summe rit wuz fine but now when it gets cold it wont always go into park or reverse. i changed my tranny fluid about 3000 miles ago
Old Nov 16, 2004 | 07:30 PM
Pssst!'s Avatar
Default Re: LS/auto shifter issue. (whiteboy4life74)
Having same problem on 93 DA9
Help Us Please
Old Nov 16, 2004 | 07:33 PM
mr.beeks's Avatar
Default Re: LS/auto shifter issue. (Pssst!)
that same used to **** me off also until I got the remedy to it!!!
Old Nov 17, 2004 | 11:57 AM
ricerwannab's Avatar
Default Re: LS/auto shifter issue. (mr.beeks)
what was the remedy to it?
Old Nov 17, 2004 | 03:12 PM
Feriofan's Avatar
Default Re: (lv6l)
I changed the fluid like 2K ago. I think that has something more to do with the electric part of the shifter, since it takes a while for the light to display in the panel.
Please any other comments, I'm tired of getting own3d by my car during cold days!
Thanks!!
hypnothaiz
Oct 7, 2004 09:13 PM
ondenoantra
May 4, 2004 06:29 AM
baddassduramax
May 13, 2003 08:15 AM
legendboy
Aug 12, 2002 12:48 PM
SteelCityKid
Apr 19, 2002 08:54 PM
