Accord won't start
I have an 88 accord 4cyl, bought it about a month ago, Fri when the cold snap came it won't start I have replaced plugs wires, cap rotor, I am playing with the timing but it just turns over then when it seems it's going to start it backfires through the carb? Yes I am getting fuel and also fire into the cylinders, those 2 elements should atleast make it start, I am at a lose right now and need help
already tried the starting fluid will try playing with the distributor in the morning had to buy a battery charger to charge the battery cause I wore it down
