auto to manual?
Old Dec 27, 2001 | 07:10 AM
Aceman64's Avatar
Default auto to manual?
anyone done this? car is a 96 hatch. know i need the pedal assembly and clutch lines and master cylinder. what else....besides a manual tranny and linkage of course.
Old Dec 27, 2001 | 07:26 AM
Spade's Avatar
Default Re: auto to manual? (Aceman64)
I believe but am not sure that you need a manual ECU as well.
Old Dec 27, 2001 | 09:33 AM
Aceman64's Avatar
Default Re: auto to manual? (Spade)
yeah probably, but i am just wondering about things other than engine parts. cause ill be getting a swap so ill get anther ecu later anyways.
Old Dec 27, 2001 | 09:54 AM
3.3.3's Avatar
its a real pain...you need the manual ecu, the linkage, all new pedals, mounts, cut into the floor base, manual tranny etc. i would only do it with a complete swap. its pointless for a d series motor.
Old Dec 27, 2001 | 10:32 AM
Aceman64's Avatar
Default Re: auto to manual? (maks)
what do you have to cut the floor base for? see im thinking if i have the pedals, master cylinder and all the lines it should just bolt up right? dont know though thats why im askin.
Old Dec 27, 2001 | 10:43 AM
BlackAxis's Avatar
I assume he means cut out a hole where the sifter is supposed to come up into the cabin.
Old Dec 27, 2001 | 10:55 AM
Aceman64's Avatar
Default Re: auto to manual? (BlackAxis)
oh ok. makes sense. it should already have the bolt holes for the rear of the linkage huh?
Old Dec 27, 2001 | 10:59 AM
Aceman64's Avatar
i assumed the body was the same, just different trannys so i thought the hole would already be there
Old Dec 27, 2001 | 11:04 AM
DR. ON POINT's Avatar
Banned
I think the whole is already there.....good luck
Old Dec 27, 2001 | 11:24 AM
BlackAxis's Avatar
Default Re: auto to manual? (On Point EK)
It might be just indented and have to punch it out.
Old Dec 27, 2001 | 11:38 AM
td04civic's Avatar
I did it on my 93 ex. You would need to get the following parts:
Master cylinder
Slave cylinder
brake pedal
clutch pedal
clutch resorvoir
manual tranny
shift linkage
shifter
shift boot
clutch
flywheel
flywheel cover
flywheel cover bolts
manual Ecu
clutch lines
manual trans. Mounts
The best thing for you to do is go to the dealer and ask them for a print out of the following diagrams:
-shift linkage
-mastercylinder/slave cylinder...this one should show you all the lines and misc. bolts that you would need.
-pedal assy. You will need alot of bolts and brackets and screws that the diagram will show.
I think thats about it. Good luck
Old Dec 27, 2001 | 11:56 AM
Aceman64's Avatar
Default Re: auto to manual (td04civic)
yeah i just bought a ek that was auto cause there hard as hell to find . and im gonna change it. my friend has a lot of the parts and so it shouldmt be too bad. thanks for the help guys.
Bright13
Dec 14, 2009 09:00 PM
96_bhr
Oct 15, 2007 02:16 PM
adamvogt28
Oct 5, 2006 07:46 PM
tegra33
Sep 23, 2004 08:07 PM
95civic17
Jul 26, 2002 04:34 AM
