where can run a mp power wire 4gauge? 1992 prelude si
Old Nov 16, 2004 | 12:29 PM
dsmarefaster's Avatar
Default where can run a mp power wire 4gauge? 1992 prelude si
i have a 1992 honda prelude si need to no where to run power wire in fire wall?
Old Nov 18, 2004 | 11:45 AM
djbrandonr's Avatar
Default Re: where can run a mp power wire 4gauge? 1992 prelude si (dsmarefaster)
On mine Iran the wire from the battery across the fire wall to the drivers side and you should see a rubber plug 12 inches or so down that you can run the wire into, than I ran it back toward the center console, all the way through the console, under the carpet into the rear console/armrest( youll have to unbolt the rear passenger side seat and console to get the wire underneath, and then into the trunk. Dont forget ro run the remote wire at the same time and any rca cables. Its a pain in the **** to do it over and over.
Old Nov 18, 2004 | 11:54 AM
95PreludeSi's Avatar
holy crap... 4 guage! What the hell are you putting in that thing?
Old Nov 18, 2004 | 12:16 PM
98TypeSH's Avatar
Default Re: where can run a mp power wire 4gauge? 1992 prelude si (95PreludeSi)
4 guage = amp power line.
Attach it to a coat hanger and fiddle it through the rubber seal.
Old Nov 18, 2004 | 12:19 PM
Siegfried's Avatar
There' s a rubber plug you can remove on the passenger side behind the fuse box.
Old Nov 18, 2004 | 12:41 PM
Jagan'92's Avatar
Default Re: where can run a mp power wire 4gauge? 1992 prelude si (Siegfried)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siegfried &raquo;</TD></TR><TR><TD CLASS="quote">There' s a rubber plug you can remove on the passenger side behind the fuse box.</TD></TR></TABLE>
That's the one I used. I also used the spare fuse slot for the 4WS, and put in a block type fuse, rather than a big inline one running to the battery. Practically invisible.
Old Nov 22, 2004 | 02:26 PM
im putiing 2 15 in subs back there orions
imadigitalgod
13
May 27, 2009 10:16 AM
datEM2
Honda Civic (2001 - 2005)
Apr 18, 2008 03:26 PM
dsmarefaster
Audio / Security / Video
Nov 18, 2004 09:52 PM
SIanara
Aug 16, 2004 10:01 PM
cd5_2NR
Apr 20, 2003 09:47 PM
