best route/ power wire
Old 08-16-2004, 05:46 PM
SIanara's Avatar
Default best route/ power wire
what is the best way to run a power wire for an amp through an integra.?
Old 08-16-2004, 06:08 PM
fcm
Old Fart
fcm's Avatar
Default Re: best route/ power wire (vteGraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteGraGSR &raquo;</TD></TR><TR><TD CLASS="quote">what is the best way to run a power wire for an amp through an integra.?</TD></TR></TABLE> Run it down the batt. side of car,[right side] there should be a rubber "dummy" plug covering a unused hole in firewall, knock a hole in "dummy" plug and use it as a grommet, run wire from hole over to kick panel and under ECU, run along floor next to rockerpanel under seat mount x members, below seatbelt bolt, inbehind rear right trim panel and behind right rear seatbelt bolt. bingo your in the hatch/trunk and noplace for the power wire to get pintched or stepped on. 94
Old 08-16-2004, 10:01 PM
becker98's Avatar
Default Re: best route/ power wire (fcm)
I just did my friends and i did it like you did/\. made me curse having a sedan
datEM2
Honda Civic (2001 - 2005)
04-18-2008 03:26 PM
EFz6er
02-04-2008 06:13 PM
01em2man
11-04-2006 10:10 AM
ilikemyaccord
Audio / Security / Video
25
08-24-2004 11:30 AM
cd5_2NR
04-20-2003 09:47 PM
Quick Reply: best route/ power wire
