My car hates being cold!!
Old Nov 16, 2004 | 12:13 PM
KeithsDAteg's Avatar
Default My car hates being cold!!
When I start my car in the mornings It dies (even when it is warn outside); unless I hold the rpms at about 2000 for about one minuet. Then, once it stays running, it only idles at about 550.
Once my car has reached "warm" it idles at about 700. I have tried everything to fix it.
What could this be?? BTW: my car is a 93 Integra.
Please help me. Thanks
Old Nov 17, 2004 | 11:57 AM
Default Re: My car hates being cold!! (KeithsDAteg)
Someone please help me, is this problem that rare??
Old Nov 17, 2004 | 12:03 PM
drdisco69's Avatar
It might not be passing the extra air for the cold start. Does it smell really rich when it's doing the stalling thing?
Old Nov 17, 2004 | 01:09 PM
Default Re: My car hates being cold!! (drdisco69)
I havent really noticed it till you said anything, but if I rev it to about 5 or 6000rpms -- it smokes and smells rich.
If you have anymore ideas please help me.
Old Nov 17, 2004 | 01:20 PM
drdisco69's Avatar
My only idea is that the cold start portion of the idle air control valve isn't working right. If you can swap another one on that would be helpful in diagnosing.
Old Nov 17, 2004 | 06:58 PM
Well... I busted out the ole' Haynes Manual.
I tested my IACV-- I started my engine and let it run until the cooling fan kicked on. Then, I pulled the connector that goes to the IACV-- my engine RPM stayed the same.
So I am gessing that I have a faulty IACV.
Thanks again
Old Nov 17, 2004 | 07:05 PM
drdisco69's Avatar
We try harder.
Old Nov 18, 2004 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">We try harder. </TD></TR></TABLE>
WHAT??
I tested the connector that goes to the IACV. It definately is getting power, so I guess my IACV is just fawked.
I have and extra one laying around though, so its all gravy.
Old Nov 19, 2004 | 12:34 PM
Well I my car is still doing the same thing..
I guess it must be some other problem.
Any suggestions??
btw I have no Cels, I think that someone took out the bulb.
end005
Sep 28, 2012 03:47 AM
trouts2
Mar 23, 2012 06:17 AM
95goldSE
Sep 12, 2007 03:38 PM
