Swapped y7 to z6 manifold...all issues fixed but...
Old Nov 16, 2004 | 11:57 AM
Nerologic's Avatar
Default Swapped y7 to z6 manifold...all issues fixed but...
It has a code 14, and it stutters at light throttle only.
For the code 14, i thought i fixed it when i went by a diagram i have...
i converted the 3 wire iacv to a 2 wire
I moved B6 -> B23 and i pulled B15 for the ECU plug
On the harnes, i pulled the orange wire (that goes to B15) and disregarded it
I moved yellow black -> green black on the new iacv plug
I moved black blue -> black on the new iacv plug
i did it all right, only thing is i think the instructions i followed were for a obd2b integ/EX/SI ECU, and we are still runnign the stock P2E, is that my error rigth there?
Next issue i have is the throttle...
the car runs fine, not on limp mode and not throwing 7 cel's (well, it threw that and more, but i fixed it all already ).
Basically it kinda stuttres at light throttle when u hold it at about 15-20% throttle like if its on limp mode or like if it was hitting the rev limit
Its not in limp mode, because after u past that point in the throttle, that goes away and the motor revs freely
so anyone have any idea?
Old Nov 16, 2004 | 12:56 PM
klungemonger's Avatar
Did you actually change the ECU or only the manifold? Because the Y7 ecu is looking for a 3-wire IACV regardless of whether you've rewired it.
I did the exact same thing and had to swap the throttle rotor & spring over to my Y7 t/b and put it back on, and repin it back to stock wiring setup. Until later on when I go to the OBD1 conversion it'll stay that way.
Hey you live in Vista! I graduated from Vista High all the way back in 1991...
Old Nov 16, 2004 | 07:12 PM
Nerologic's Avatar
Default Re: (klungemonger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">Did you actually change the ECU or only the manifold? Because the Y7 ecu is looking for a 3-wire IACV regardless of whether you've rewired it.
Hey you live in Vista! I graduated from Vista High all the way back in 1991...</TD></TR></TABLE>
damn yeah were going to convert the car to obd1, so i guess were screwed till we convert...
we kept the P2E, all we did was swap in teh z6 intake manifold....
damn 91? haha u might know some of my cousins...
Old Nov 17, 2004 | 12:15 AM
Nerologic's Avatar
upp for my second issue...
Old Nov 17, 2004 | 05:48 AM
Default Re: (Nerologic)
I think the second issue may be related to the first issue. Whenever I let off the throttle the car would bog a little, and when I pressed it again it would surge or stutter. I think because it's starved for air with the IACV not working and when you even hit the pedal slightly it gets a rush or something. That went away when I put the wiring back to stock.
Old Nov 17, 2004 | 09:37 AM
Nerologic's Avatar
damn...i guess we need to conver the car to OBD1 ASAP...hahah
mjrino
Apr 17, 2008 12:07 PM
gourley
30
Jul 2, 2007 10:04 PM
spastik
Dec 1, 2006 12:02 PM
0 0 0
Feb 7, 2005 12:20 PM
EGRhatch
Feb 1, 2004 08:23 PM
