Good tranny fluid...Whats your recommendation? (getting slight 3rd gear grind)
Old Nov 16, 2004 | 09:12 AM
Collateral's Avatar
B A N N E D
Default Good tranny fluid...Whats your recommendation? (getting slight 3rd gear grind)
I have a 2000 Civic Si and just recently 3rd started to grind. If I shift slowly, it wont do it...however anything above 5,000 rpms...causes a slight grind normally shifting into 3rd.
Ive read a few previous post and remembering people occuring this same problem, however changing over to a nice tranny fluid..sometimes made it go away.
Any of you guys recommend a certain tranny fluid, that make this problem go away? If so, what and where do I buy this fluid?
Thanks for any help you can provide
Old Nov 16, 2004 | 09:15 AM
BauleyCivic's Avatar
Risky Business
Default Re: Good tranny fluid...Whats your recommendation? (collateral)
GM Synchromesh Friction Modified
Ricey McRicerton's Avatar
GM Synchromesh FM
EDIT: God I'm too slow
Old Nov 16, 2004 | 09:24 AM
Collateral's Avatar
B A N N E D
Default Re: Good tranny fluid...Whats your recommendation? (BauleyCivic)
Thanks BauleyCivic, You gotta stop helping my slow *** out so much...Imma gonna owe you a "Bentley" by the end of year..the rate Im goin
Thanks again guys..
Old Nov 16, 2004 | 09:26 AM
pdiggitydogg's Avatar
GM synchromesh part #
12377916
Old Nov 16, 2004 | 09:40 AM
Average Al's Avatar
HANDS down synchromesh
been using for a year now and this **** is jesus fuild i swear
Old Nov 16, 2004 | 09:49 AM
Collateral's Avatar
B A N N E D
Default Re: (pdiggitydogg)
Without me having to look for it, how many quarts should I buy for a 2000 civic Si B16 S4 tranny?
Old Nov 16, 2004 | 10:08 AM
ejprimo's Avatar
Default Re: (collateral)
gm syncromesh part# 12346190
Old Nov 16, 2004 | 10:19 AM
jdmitr98's Avatar
i believe the correct amount is 2.2 quarts so you will have to get 3, but I can never seem to get more than 2 in my tranny? who knows!
Old Nov 16, 2004 | 10:33 AM
Collateral's Avatar
B A N N E D
wow, I just called Chevy..and they said its 22.00 a quart! Is that what you guys paid for it?
Old Nov 16, 2004 | 10:43 AM
LoSt is BlaCk's Avatar
if that;s too much for you you can also try the penzoil syncro shizzle too, it worked my me...and my buddy
Old Nov 16, 2004 | 10:52 AM
Filliam H. Muffman's Avatar
difference between syncromesh, and syncromesh FM?
Because I just put a quart of regular syncromesh into my car.
Old Nov 16, 2004 | 10:55 AM
Allmotor2o9's Avatar
Default Re: Good tranny fluid...Whats your recommendation? (LoStMyBoOsT)
$22....... that sounds right....
SkoundrelUSA's Avatar
cute little bastard
Honda Manual Transmission Fluid sucks ***. Should've got the Sychromesh but I'm a cheap bastard. Don't go cheap like me.
Old Nov 16, 2004 | 10:59 AM
Stoich EG2's Avatar
Default Re: Good tranny fluid...Whats your recommendation? (SkoundrelUSA)
syncromesh and honda tranny fluid is about the same. friction modified is used on LSD trannys but you can use it on your regular.
Old Nov 16, 2004 | 11:00 AM
JDM Like Whoa's Avatar
I am using redline shockproof lightweight. Its around 5-8 dollars a qt. It got rid of my grinds and tranny isnt edgy anymore.
Old Nov 16, 2004 | 11:04 AM
careawholelot's Avatar
Default Re: (ImportRacr05)
redline has been good for me, i also use gm synchromesh which has been good for me.
Old Nov 16, 2004 | 11:05 AM
ejprimo's Avatar
Default Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">gm syncromesh part# 12346190 </TD></TR></TABLE>
this is the full synthetic syncromesh made by castrol. you can get it for $11-12/qt. at gmpartsdirect.com
Old Nov 16, 2004 | 11:21 AM
egtype-r's Avatar
there was a crazy thread about this awhile ago...
search under user in archives (egstreethtch)
Old Nov 16, 2004 | 11:24 AM
Collateral's Avatar
B A N N E D
Default Re: (egtype-r)
thanks for all the responses guys,
So what its come down too ...is should I buy the GM sychromesh or Redline Tranny fluid?
Any experience both? If you like Redling oil better...what exact model did you get and if so..what is the part number?
I just want to experience and "try" to get rid of the grind...I dont really care of the cost factor.
Thanks guys again for all your knowledge and help
Old Nov 16, 2004 | 11:58 AM
PupaScoopa's Avatar
Default Re: Good tranny fluid...Whats your recommendation? (AllDsD1motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllDsD1motor &raquo;</TD></TR><TR><TD CLASS="quote">$22....... that sounds right....</TD></TR></TABLE>
$22 is WRONG!! Get it for $12/qt at gmpartsdirect.com.
Old Nov 16, 2004 | 12:42 PM
Inspector Gadget's Avatar
Default Re: Good tranny fluid...Whats your recommendation? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">
$22 is WRONG!! Get it for $12/qt at gmpartsdirect.com.</TD></TR></TABLE>
****, I payed $28/qt.
Old Nov 16, 2004 | 01:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Good tranny fluid...Whats your recommendation? (Inspector Gadget)
wow, I get that stuff for 8 bucks a quart....maybe I should buy a bunch and sell it to you guys
Old Nov 16, 2004 | 01:09 PM
93CivicSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">GM Synchromesh Friction Modified
Old Nov 16, 2004 | 01:10 PM
Collateral's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">gm syncromesh part# 12346190 </TD></TR></TABLE>So guys is this the one I should order?? Is this the Sychromesh FM?
