how many dash bolts
Old Nov 16, 2004 | 05:45 AM
crxhftosi's Avatar
Default how many dash bolts
does anyone know how many dash bolts there are and where they are located in my 89 crx pls help thanks
Old Nov 16, 2004 | 05:51 AM
ExplicitSpeed's Avatar
Default Re: how many dash bolts (crxhftosi)
There is 4 main ones and I think 2 other ones. The main ones are: one is on the dash near the window center of the car has a little trap door you need to flip up and I think its a 10mm. Then there is one under the console where the metal frame of the console is bolted down to the chasis. Then there is One on each side of the vents where it sends air thourh ur air conditioning and heatind to the door panels. You will see it once you open your doors. You can see in the vents also and see them. There is another one near the fuse box under the dash I believe. Then there should be another behind the glove box on the right one of the big bolts. And if there is another It must be the bent tubing that is connected to the floor under the center console. Its been a while...but i think that is it hope this helps
Old Nov 16, 2004 | 07:51 AM
NCRXSi's Avatar
https://honda-tech.com/zerothread?id=1056015
Old Nov 19, 2004 | 06:01 AM
crxhftosi's Avatar
Default Re: how many dash bolts (ExplicitSpeed)
thank you i will find out today
Old Dec 2, 2004 | 05:43 AM
crxhftosi's Avatar
thanks got it out it helped alot
Hondaman56
Sep 20, 2008 02:57 PM
B_Something
Dec 29, 2007 09:07 AM
si90rex
Sep 22, 2007 05:30 PM
94CRVtec
Jul 22, 2004 01:19 AM
