help!!
Old Nov 15, 2004 | 07:39 PM
beat_nut's Avatar
Default help!!
i have a 99 civic ex. im installing a autometer monstertach with shift light. it says im suppose to connect the green wire to the Coil or the electronic ignition-(tach terminal). i know i dont have a coil, but where is the electronic ignition in my vehicle located?
Old Nov 15, 2004 | 07:43 PM
allmotaeg6's Avatar
Default Re: help!! (beat_nut)
i believe its the blue wire coming from the distributor the you want to tap into...but dont you already have a tach ?
beat_nut's Avatar
Default Re: help!! (pr0ject Eg6)
i will try that out. thanks i appreciate the help
Old Nov 15, 2004 | 09:00 PM
beat_nut's Avatar
are u guys sure its the blue wire??
Old Nov 15, 2004 | 09:17 PM
allmotaeg6's Avatar
blue wire coming out of the driver side firewall
Old Nov 15, 2004 | 09:18 PM
allmotaeg6's Avatar
https://honda-tech.com/zerothread?id=800671.... read that
Old Nov 15, 2004 | 09:24 PM
beat_nut's Avatar
hmmm. ok so i connected the tach to the blue wire coming (DIRECTLY) out of the distributor. the tachometer, was fluttering all over the place, and when my motor was idling, the tach registerd like 5000 rpm. hahah. I havnt tested out the blue wire coming (DIRECTLY) out of the driver side yet because my dads making me go to bed. But tomorrow i will test it out and let you guys know the results......thanks for helping me out. (goin to bed so ill check posts tomorrow after school)
PS: you guys sure its the blue wire coming out of the driver side? cuz i havnt looked for that wire yet. (is their a blue wire coming out of driver side firewall?)
Old Nov 15, 2004 | 09:26 PM
allmotaeg6's Avatar
if its fluttering then you have a bad ground
Old Nov 16, 2004 | 02:45 PM
beat_nut's Avatar
Default Re: (pr0ject Eg6)
alright! i connected the green wire to the blue wire coming out of dash. All i gotta say is its working, and thanks for your help. appreciate it!
Dropped90Integra
Jan 13, 2005 08:57 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
THCRXsi
Nov 28, 2002 08:06 PM
projectcrx
May 15, 2002 10:36 PM
89hondarex
Aug 29, 2001 09:42 PM
