Black Vacuum Box
Old Nov 15, 2004 | 06:47 PM
ferio 95's Avatar
Default Black Vacuum Box
I found this black box under my intake manifold all cracked up. it seems to be a vacuum box and could have been the cause of my vacuum leek issue. basically wtf is it do i need it? Motor is a 94 GSR
Old Nov 15, 2004 | 07:27 PM
mmuller's Avatar
Mad Scientist
Default Re: Black Vacuum Box (ferio 95)
its your iab box.
Old Nov 16, 2004 | 05:34 PM
ferio 95's Avatar
Default Re: Black Vacuum Box (mmuller)
and what does it do and do i need it
Old Nov 16, 2004 | 06:01 PM
mmuller's Avatar
Mad Scientist
its for your secondaries, just get another one
Old Nov 16, 2004 | 07:24 PM
ferio 95's Avatar
what if i removed them can i just take it out the system and not worry about it?
Old Nov 17, 2004 | 07:05 PM
ferio 95's Avatar
bump need answer
Old Nov 17, 2004 | 08:44 PM
notstock93's Avatar
you can, but the the IAB wouldnt work and you MAY throw a code, im not sure on that one.
Old Nov 17, 2004 | 10:18 PM
ferio 95's Avatar
Default Re: Black Vacuum Box (notstock93)
ok so if i removed the IAB from my manifold and remove the box ill be fine?
Old Nov 17, 2004 | 10:29 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 &raquo;</TD></TR><TR><TD CLASS="quote">ok so if i removed the IAB from my manifold and remove the box ill be fine?
depending on your mods; you will loose power in the low-mid range
Old Nov 18, 2004 | 12:26 PM
ferio 95's Avatar
Well ive already removed them from the manifold and the box is fuxord so what im asking basically can i just loop the vacuum lines and be ok? Im running two different ecu's a p30 + p28 since they both dont read IAB's
WHen removing the IABs from the manifold you will lose a few ponies under vtec. but running on a ps28 or p30 ecu you wont notice it. when you get in vtec the high rpm's 6000-8,500 pull alot harder its just like if you got a skunk 2 manifold
Old Oct 12, 2005 | 08:09 PM
gsrvtec2's Avatar
wow i luv it... vacuum box eh... exactly wat i need to run my secondary
JDMEJ!
Aug 31, 2012 02:14 PM
anonymus913
Jul 28, 2011 06:14 PM
Lewdin' Incognito
Sep 2, 2005 03:44 AM
B00ST2nR
Nov 5, 2003 12:49 AM
fastludeh22
Aug 26, 2003 06:46 AM
