Two amps to one sub.
Old Nov 15, 2004 | 06:23 PM
tca0bell's Avatar
Default Two amps to one sub.
I have one amp that is 100 watts and an amp that is 250 watts. is it possible to hook both amps to one sub for 350 watts? its a dvc sub.
Old Nov 15, 2004 | 06:39 PM
Auex's Avatar
Default Re: Two amps to one sub. (tca0bell)
NO, Never mix amps of different wattage on the same sub. If you wanted to bi-amp a sub(usually must be a DVC) you should use two of the same amps and would be wise to set it up with an O-scope.
Old Nov 15, 2004 | 06:47 PM
tca0bell's Avatar
Default Re: Two amps to one sub. (Auex)
oh. i have another question, is it possible to use a mono amp for my mids? its supose to be for a sub cause it has lpf's on it but i can turn it off.
Old Nov 15, 2004 | 06:50 PM
Auex's Avatar
You can use a mono amp but it won't sound right IMO.
Old Nov 15, 2004 | 06:57 PM
tca0bell's Avatar
why? will it sound like a sub? wont go as high? my mids have crossovers on them so i can put them on the high output and plus i have tweeters so u think it will even out?
Old Nov 15, 2004 | 07:02 PM
Auex's Avatar
It will sound wierd because it will be mono, you are used to listen to music in stereo. That is the only reason. As long as the LPF can be disabled then you are good.
Old Nov 15, 2004 | 07:18 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">It will sound wierd because it will be mono, you are used to listen to music in stereo. That is the only reason. As long as the LPF can be disabled then you are good.</TD></TR></TABLE>
and chances are if its a mono amp its a class D. very limited frequency range even without the LPF and generally have a high THD when compared to the class a/b's
deerman2701
Audio / Security / Video
Feb 16, 2008 11:51 PM
JohnnyEF
Nov 26, 2006 12:04 PM
pezzy
Aug 28, 2004 09:20 PM
technine
15
Jun 15, 2004 08:04 AM
SSBP DC2
Apr 18, 2003 12:22 AM
