H-series 2.4L VTEC 4th Gen. Turbo ... Problems??
Old Nov 15, 2004 | 11:35 AM
illude9357's Avatar
Default H-series 2.4L VTEC 4th Gen. Turbo ... Problems??
I was playing with the idea of making a 2.4L H22A1 (H23A1 Crank and 89mm sleeves)... and then turbocharging the project... All the added displacement will give the turbo a nice kick in the *** , but I was wondering what kind of problems I might be looking at... Before I start dumping money into this project... I tried searching, but didn't really find anything...
Thanks.
Old Nov 15, 2004 | 11:40 AM
Shakes's Avatar
space cadet
Default Re: H-series 2.4L VTEC 4th Gen. Turbo ... Problems?? (illude9357)
89mm is too small to start out at. if anything happens to the cylinder wall it had better be fixable in that 1mm or you will be resleeving.
too close IMHO.
Old Nov 15, 2004 | 12:18 PM
SRP's Avatar
SRP
Stick with the stock stroke and stay with a 88mm bore maximum.
read this thread: https://honda-tech.com/zerothread?id=1053215
Old Nov 15, 2004 | 02:12 PM
DLB1994's Avatar
Default Re: H-series 2.4L VTEC 4th Gen. Turbo ... Problems?? (SRP)
keep the bore small ,87.5 or 88mm , but u can run a h23 crank its worth the tq for the heavy car
Old Nov 15, 2004 | 02:51 PM
grappler's Avatar
If you go 89 bore use darton m.i.d kit sleeves, they give you iron cylinder walls.
95blackegcoupe
Aug 17, 2006 06:18 PM
JR Integra
Aug 16, 2004 11:21 PM
black_rude_lude
Jul 28, 2004 02:36 AM
Redlinin fo EVA
Sep 21, 2001 01:04 PM
