Could this be a solution for traction problems in big HP cars?
Old Nov 15, 2004 | 10:53 AM
Boostage's Avatar
Default Could this be a solution for traction problems in big HP cars?
http://www.racelogic.co.uk/traction/
"Front wheel drive cars
If your powerful front wheel drive car is prone to wheelspin or power understeer, then the Traction Control system will give a good benefit. Coming out of tight hairpins the throttle can be buried, and the system modulates the power extremely quickly to provide maximum acceleration without wasteful wheelspin. As you turn into a corner, the throttle again can be buried, and instead of drifting wide of the apex as the front wheels scrabble for grip, the car will power through the corner at the maximum speed without understeering. This will reduce tyre wear quite considerably, and improve performance. In the wet the system comes into it's own, you will go at least 1 or 2 seconds per kilometre quicker, and in tight slippery conditions it will be much more. We have fitted the system to a number of tarmac cars, and in the wet they even outpace some 4wd cars! "
its a universal system that will work on any car, they even sell wheel speed sensors if you dont have ABS.
Old Nov 15, 2004 | 11:49 AM
Kamin's Avatar
Default Re: Could this be a solution for traction problems in big HP cars? (Boostage)
i dont know about outpace a AWD car but yes, its a good idea. its pretty much on every new performance car. its just anti slip. some cars modulate it with the brakes, some do it with the throttle (electronic TPS, no cable)
Old Nov 15, 2004 | 11:59 AM
Boostage's Avatar
Default Re: Could this be a solution for traction problems in big HP cars? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about outpace a AWD car but yes, its a good idea. its pretty much on every new performance car. its just anti slip. some cars modulate it with the brakes, some do it with the throttle (electronic TPS, no cable)</TD></TR></TABLE>
do u think it has many limits? example.. with a good non drag radial street tire do you think it could help a 400hp car perform better than a car with same setup except no traction control and drag radials?
Old Nov 15, 2004 | 01:26 PM
Andy M's Avatar
I built one of these for my R/C car using optical sensors instead of hall effect. I'll post video of it in action some time.
Old Nov 15, 2004 | 01:28 PM
Kamin's Avatar
theoretically yes, no matter how much HP you have, you cant go faster than traction allows.
as for real world, i dont know. never used it.
Old Nov 15, 2004 | 02:45 PM
TurboGS-R's Avatar
Sorry, this is off-topic, but nice 240.
juststart
Honda CR-V & Element
May 2, 2015 04:07 PM
Ludakidd97
May 11, 2006 02:40 PM
Jay J
Sep 4, 2005 06:06 PM
kelvinchau25
Sep 2, 2005 11:48 PM
Boostage
Jan 4, 2005 08:57 AM
