Valve adjustment help please
I just installed a street/strip CompCam on my D16 VTEC and needed help adjusting the tapets (i think that's they're it's called) for the difference. I adjusted it back to stock, but i think it's still to far because of the noise. Would anyone happen to know the gaps that would work best? Or if you any, suggestions on what to do would help...thanx
i think mine right now is .008 in and .010 ex. Do you have this cam or are you just giving a suggestion? I don't want to crap my motor out.
those are the stock specs, lash should be the same with the zex as w/ stock.
BTW .010 is still with in spec
spec is .07-.09 intake
.09-.011 exhaust
.09-.011 exhaust
Well it's supposed to work with and on stock settings (i believe), but what i'm worried about is the noise from the valves being slammed down. In other words, it .007/.009 going to quite it down.
Ruben19
May 25, 2009 01:05 PM
