NOW U HEAR AND FEEL IT NOW YOU DON'T?
Old Nov 14, 2004 | 07:47 PM
civic91's Avatar
Default NOW U HEAR AND FEEL IT NOW YOU DON'T?
hi there! i've been experiencing this weird shaking and like a dribble noise in my 95 gsr with 122,xxx miles. the problem is the noise is on and off. yesterday i was driving at I-20 and suddendly i felt the shaking and hear the noise. the steering wheel is not shaking or vibrating but i can feel the front of the car is shaking, and when i let go off the gas the shaking and noise dissappear. and when i press the gas again, the car shakes and the dribble noise is back. then i stop at a local supermarket and on my way home the shaking and the noise dissappear. what do you think the problem of my car? need your expertise please. thanks for any input.
Old Nov 14, 2004 | 08:08 PM
FlaN.'s Avatar
sounds like your heatshield is coming aloose. check all your heatshields for corrosion and fix/replace/rip out the culprit.
Old Nov 15, 2004 | 04:52 AM
civic91's Avatar
Default Re: (FlaN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlaN. &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your heatshield is coming aloose. check all your heatshields for corrosion and fix/replace/rip out the culprit.</TD></TR></TABLE>
not the heatshield. anybody please....
Old Nov 15, 2004 | 06:45 AM
JimBlake's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (civic91)
Wobbling only with power suggests your drive axles. Check them out, see if anything's loose. Also loose balljoints on the steering tierods.
It's possible that parts of a tire are separating. Have someone drive alongside while you accelerate. Look for a tire that squirms & wobbles funny when you're on the gas pedal.
Old Nov 15, 2004 | 10:48 AM
civic91's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Wobbling only with power suggests your drive axles. Check them out, see if anything's loose. Also loose balljoints on the steering tierods.
my tires is not even a year old (all of them) i had an alignment after installing all four tires and few weeks ago i had my tires rotate and balance because of this unusually noise/shaking/vibrating that gets louder as I increase speed and dissappear when I let go of the gas. is it expensive to replace axle?
Old Nov 15, 2004 | 11:21 AM
MR-MUGEN's Avatar
its the drive axles my car starts doing that about every 6000-10000 miles all depends on how i drive , how low is you car
Old Nov 15, 2004 | 01:23 PM
civic91's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (jdm92daintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra &raquo;</TD></TR><TR><TD CLASS="quote">its the drive axles my car starts doing that about every 6000-10000 miles all depends on how i drive , how low is you car </TD></TR></TABLE>
my car is almost stock, all i have in my car is SRI and comptech header.
Old Nov 16, 2004 | 01:36 AM
MR-MUGEN's Avatar
but when is the last time you changed them
Old Nov 16, 2004 | 04:37 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra &raquo;</TD></TR><TR><TD CLASS="quote">but when is the last time you changed them </TD></TR></TABLE>
haven't change the axle since i bought the car. any suggestion on where to get an axle?
Old Nov 16, 2004 | 04:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 &raquo;</TD></TR><TR><TD CLASS="quote">... any suggestion on where to get an axle?</TD></TR></TABLE>Dealer, AutoXone, http://www.ahmotor.com, call around to lots of places. Search for axles, if you wanna read opinions about who's good & who's not.
Are you thinking about replacing them yourself? There's posts about that, too.
Old Nov 16, 2004 | 10:34 AM
MR-MUGEN's Avatar
lol.... just so you know the axle are the ones that go from the tranny to the wheels , o and the bolt that holds them to the hub of the wheel are not easy **** to take off . you got to have huevos or a are gun , &lt;--- thats what i use , so just take it to a shop and let them do it , unless you think you know how
Old Nov 16, 2004 | 12:45 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Haha, i spent 4 hours trying to get my axles off without an impact gun and whatnot. Invest in some stage 1 axles or go somewhere that has a life time guarn teeee.
Old Nov 16, 2004 | 01:02 PM
RSVTECDC4's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (Mattb16teg)
took me 1 whole day of trying to get the axle nut off.. haha.. just drilled a hole through that sucker and chiseled it apart
Old Nov 16, 2004 | 04:57 PM
95BlkGSR's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (RSVTECDC4)
i got a wobbling also 95 gsr 111,xxxmiles...but mine is when i brake, its not tires or brakes i got new both...
Old Nov 17, 2004 | 03:06 AM
MR-MUGEN's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (95BlkGSR)
^^ aliment , o and it takes me like 10min. to change an axle , hehehe impact gun
Old Nov 17, 2004 | 04:56 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Dealer, AutoXone, http://www.ahmotor.com, call around to lots of places. Search for axles, if you wanna read opinions about who's good & who's not.
I call the dealer and they what $399 ea.+tax, just the axle, labor is separate. Haven't call autozone and o'reilly. No, I'm not planning on replacing it myself. A knowledgeble HT member told me to avoid CCT rebuilt axle from autozone.
Old Nov 17, 2004 | 05:20 AM
burnout289's Avatar
I got axles from Kragen for super cheap. most shops are going to charge you $150 per side just to put them on.
as for the axle nut, I dunno why everyone had so much trouble. I just used a big freakin ratchet and used my superior MUSCLES. of course, to get it to turn, you have to bend out the endge that was punched in to keep it from vibrating loose.
even though there is a lot of material about this on HT, I would suggest taking it somewhere if you can afford it. just make sure it's a reputable shop. the place that did mine for 1/2 the price everyone else asked had morons for mechanics. they told me one axle was too short...it didn't match the one off the car. I went down there and told him to pull the axle apart from the intermediate shaft. "see? same size." dumbass.
Old Nov 17, 2004 | 10:33 AM
MR-MUGEN's Avatar
Default Re: NOW U HEAR AND FEEL IT NOW YOU DON'T? (burnout289)
try a performance show they wont charge you as much , becuase it doesn't take that long
vi3tromanc3r
12
Nov 9, 2006 02:45 PM
...rohit
May 5, 2006 09:13 AM
citrus3000psi
Jun 7, 2005 10:37 AM
typeee
Nov 21, 2003 01:05 PM
blancoteg
Aug 26, 2003 06:50 PM
