LS/VTEC not starting HELP
Old Nov 14, 2004 | 07:43 PM
GWInquisitor14's Avatar
Default LS/VTEC not starting HELP
My swap consists of an B18b block w/ a B16 head on it. I cannot get the car to run properly. The cam timing is setup correctly, crank at TDC and cam hashmarks line up. Any susgestions on what i should do or should i take it to a shop? King motorsports is within 20 minutes of my house so i could tow it there or would it be better to take it to the acura dealership? Id like to fix it myself but i think I dont have enough time and tools to do it myself. Thanx
Old Nov 14, 2004 | 09:15 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC not starting HELP (GWInquisitor14)
more details.
the car dont start or you cant get it to run right?
Old Nov 15, 2004 | 11:59 AM
Default Re: LS/VTEC not starting HELP (mmuller)
it starts but it runs really bad.
Old Nov 15, 2004 | 02:14 PM
honda head's Avatar
dose it have idle serge, miss-fire, what kind of ecu are you runing? check your valve lash.
Old Nov 15, 2004 | 04:34 PM
b18cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GWInquisitor14 &raquo;</TD></TR><TR><TD CLASS="quote">it starts but it runs really bad. </TD></TR></TABLE>
Please elaborate. Need somewhere to start. What have you already tried? Bad gas? Plug wires in wrong order? Distributor Timing? Any check engine codes?
Old Nov 15, 2004 | 05:13 PM
Default Re: LS/VTEC not starting HELP (b18cx)
i have a 1 check engine code, but its a throttle position sensor code. The plug wires are in the right order and the dizzy timing is set correctly. Ill check the valve lash but would that really make the car idle very bad? This is like a horrible idle, barely running idle.
Old Nov 15, 2004 | 05:22 PM
Widebody1's Avatar
you probably just answered your own question of why it dosent run right. Fix the tps.
Old Nov 15, 2004 | 05:28 PM
Default Re: LS/VTEC not starting HELP (Widebody1)
would that really affect it THAT much?
Old Nov 24, 2004 | 09:09 PM
Well it turned out it was the cam timing, dunno how i couldn't have had it set up correctly but it wasn't.
hfhondacrx
Sep 19, 2007 05:26 AM
aznwash3wboi
May 2, 2006 02:30 PM
jdm91CrxSi
Mar 3, 2006 03:11 AM
ToNY2012
Jan 23, 2006 05:28 PM
incognitoracerr
Sep 30, 2003 04:46 PM
