Hesitation under load / temporary loss of power. MAP or dist?
Old Nov 14, 2004 | 10:15 AM
SkRiBLaH's Avatar
Default Hesitation under load / temporary loss of power. MAP or dist?
sometimes when driving under partal throttle, the engine hesitates and there is no power, but if i let my foot off the gas completly , then put it back it works as normal.
map sensor problem or distributor cap?
or somthing else??
Old Nov 14, 2004 | 03:56 PM
asubennett's Avatar
Default Re: Hesitation under load / temporary loss of power. MAP or dist? (SkRiBLaH)
I would think MAP sensor based on the sporadic arrival of the problem.
Old Nov 14, 2004 | 07:19 PM
JLange's Avatar
Default Re: Hesitation under load / temporary loss of power. MAP or dist? (asubennett)
check your o2 synsor too
Old Nov 14, 2004 | 07:34 PM
blk_db2's Avatar
what mod's do you have.......
I had the same problem, but I've got high compression ~ 11.4cr.......
I changed my o2 sensor, cap/rotor, wires and fuel filter and they didn't do ****!
mine turned out to be......., I had wrong timing and the wrong spark plugs (to hot)
Greg1995Civic
Oct 23, 2014 07:54 AM
bertooo
Nov 7, 2011 11:28 PM
goula SOS
Jul 20, 2003 08:14 PM
