ctr pistons in b16a2
Old Dec 26, 2001 | 01:09 PM
chad's Avatar
Moderator
Default ctr pistons in b16a2
how much will they raise the compression with stock head gasket, with spoon head gasket?
better yet which head gasket should i run?
if i mill the deck .0020th's what will compression be then? will there be clearance problems? and also which head gasket should be used? stock or an ultra thin?
what is the formula for figuring compression?
[Modified by chad, 10:14 PM 12/26/2001]
Old Dec 26, 2001 | 01:46 PM
samiam's Avatar
Default Re: ctr pistons in b16a2 (chad)
i think 11:1 ish?? Stock. but with your mods it might go skyhigh.
Old Dec 26, 2001 | 02:32 PM
rainforest's Avatar
11.1 is right with .020 off it would be .4 more than with out it milled. also you have to rember to mill the rod a little more than 1mm on each side of the rod to make them fit.
[Modified by rainforest, 11:33 PM 12/26/2001]
awdriscol4
Jan 7, 2005 06:35 PM
vtekthis
Nov 2, 2004 07:17 PM
fastludeh22
Oct 14, 2002 01:52 PM
RTW DC2R
May 24, 2002 06:52 AM
