boost control question..turboed ITRS help
Old Nov 13, 2004 | 09:36 PM
MostlyR's Avatar
Default turboed ITR boost control
currently, i am using a greddy boost controller running at 0.45 bar which is equivalent to 7psi. Is there anything I can buy or do to make the turbo run at a lower psi, preferably 4 psi? Or is there a way i can just turn off the turbo completely while leaving the turbo kit and intercooler under the hood?
Old Nov 13, 2004 | 10:05 PM
uNF$@#!'s Avatar
Default Re: turboed ITR boost control (PY Type R)
lol
ok. i'll bite. get a 0.35 bar waste gate and stop wasting everyones time and do research before you blow up your integra.
i know near to nothing about turbo applications, yet i still know enough to know you know absolutely nothing.
Old Nov 13, 2004 | 10:30 PM
Eluder200K's Avatar
Default Re: turboed ITR boost control (255.255.255.255)
You will get much more help if you post in the FI forum https://honda-tech.com/zeroforum?id=16
Old Nov 14, 2004 | 04:50 AM
Syner-G-Racing LLC's Avatar
just remove the spring cause from the sounds of it you dont need to be boosting any way.
Old Nov 14, 2004 | 08:15 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY Type R &raquo;</TD></TR><TR><TD CLASS="quote">currently, i am using a greddy boost controller running at 0.45 bar which is equivalent to 7psi. Is there anything I can buy or do to make the turbo run at a lower psi, preferably 4 psi? Or is there a way i can just turn off the turbo completely while leaving the turbo kit and intercooler under the hood? </TD></TR></TABLE>
Heh. Why? Looking for a "valet" mode or just worried about your motor?
Turn the boost controller off, that'll let you run on the wastegate spring, and will be the lowest PSI you can get without getting a new WG spring (unless you can loosen that spring somehow)
http://www.greddy.com/prod_relief_valve.htm --&gt; This would be a bastard way to do it... but you could set the relief valve (basically a BOV that opens at a certain pressure). You can set it for like 1.5 PSI if you wanted to.
-Chris
1991hb
Nov 9, 2007 02:42 PM
eghatch16
Sep 23, 2006 10:32 AM
floored4door
Jun 6, 2006 05:31 PM
IZsd
May 6, 2003 12:17 PM
TurboB18C1
Jul 13, 2002 07:19 PM
