Need Advice: Bleeding Boost w/o over spining the turbo.
Issue is.... My turbo kit will be installed in the next few days, I have to drive from my crib to my tuner which is approx 76 miles away. I am worried about boosting. What is the best way to bleed the boost without overspinning the turbo? If I take the spring out of the gate that will let out all the boost correct? But inturn will that overspin the turbine?
One of my friends can burn me a map that is super rich so incase i tap into boost I have a ton of fuel... What is my best bet?
Re: Need Advice: Bleeding Boost w/o over spining the turbo. (floored4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by floored4door »</TD></TR><TR><TD CLASS="quote">Issue is.... My turbo kit will be installed in the next few days, I have to drive from my crib to my tuner which is approx 76 miles away. I am worried about boosting. What is the best way to bleed the boost without overspinning the turbo? If I take the spring out of the gate that will let out all the boost correct? But inturn will that overspin the turbine?
One of my friends can burn me a map that is super rich so incase i tap into boost I have a ton of fuel... What is my best bet? </TD></TR></TABLE>
with external wastegate, take the spring out and you won't go past 0psi.
Re: Need Advice: Bleeding Boost w/o over spining the turbo. (vtec.dc2)
I understand that, but the engine will still be spinning the turbine. I don't want to overspin the turbo.
Re: Need Advice: Bleeding Boost w/o over spining the turbo. (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">you won't - it will be fine.</TD></TR></TABLE>
brasilstreet
06-16-2004 02:21 PM
