Fields and MAP code!?!?!?
Old Nov 13, 2004 | 09:31 PM
sicivic's Avatar
Default Fields and MAP code!?!?!?
I keep getting a 3 blinkes code on my ECU but no check engine light. I'm running a Fields SFC-Vtec controller and have it soldered into the wiring harness right before the ECU. 3 blinkes is the MAP sensor code, correct? Anyone else had this problem? Setup is PM6 ECU. I've reset the ECU many times and it keeps coming back on.
Old Nov 13, 2004 | 10:08 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
3 blinks is map. check continuity of your solder joints, then try removing map and see if it (the sensor) holds vaccuum with a vaccuum gauge. it should. if it does, start the motor, let it idle and check to feel suction in the throttle body hole where the map sits. if you dont, its blocked by something.
if this doesnt do it, check continuity from the map sensor plug all the way to ecu lead at pin 14 (green/white) and 15 (yel/red) for obd-0
Old Nov 13, 2004 | 10:35 PM
BoostBoi's Avatar
Default Re: Fields and MAP code!?!?!? (sicivic)
I just got a Feilds VAFC for my CRX, can you please send me a copy of the Wiring Diagram. for the PM6
Thanks, Bryan
Old Nov 13, 2005 | 10:01 AM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: Fields and MAP code!?!?!? (BoostBoi)
damm it, Im having this problem right now and searched this up. Did you ever get it fixed?
Old Nov 28, 2005 | 07:51 PM
sicivic's Avatar
Default Re: Fields and MAP code!?!?!? (NAS_OCSICNARF)
I don't think I've fixed it. I heard that the Fields can cause this problem. I'm thinkin about ditchin the Fields for either a simple rpm activated switch or I might upgrade to a P28 OBD-1 setup with harness and everything.
95gsrEG
Feb 17, 2009 06:45 AM
speedooo
11
Jul 24, 2008 09:27 AM
krz6jdm
Feb 21, 2006 01:36 AM
Xsi
Sep 23, 2002 07:50 AM
logistixz
Jun 20, 2002 01:06 PM
