will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg?
Old Dec 26, 2001 | 10:42 AM
Brian_92GSR's Avatar
New User
Default will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg?
AEM doesn't have a fuel rail for a 92 integra, but I've heard the 3rd gen fuel rail would fit. I've looked at a 94 integra and it looks very similar to my 92, but there could be minor differences. Can anyone confirm that they are the same?
Old Dec 26, 2001 | 10:49 AM
EP3_05's Avatar
Default Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (Brian_92GSR)
Venom performance makes a fuel rail for your car:
Check out: http://www.venom-performance.com/
Old Dec 26, 2001 | 11:52 AM
PM-Performance's Avatar
Default Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (91civic)
they fit all b series motors last time i checked.
yours is a b series. so it will fit.
Old Dec 26, 2001 | 12:36 PM
dustin's Avatar
The only difference is where they position the fuel inlet banjo bolt. The 3rd gen teg has the fuel filter higher up on the firewall.
Dustin
Old Dec 26, 2001 | 12:39 PM
91DA9's Avatar
Default Re: will an AEM fuel rail for a 3rd gen teg fit a 2nd gen teg? (dustin)
hey brian did you cacel your order?
I told you that there should be no reason that it wouldn't work for any B series Intake Manifold.
Old Dec 26, 2001 | 01:42 PM
New User
Alright, thanks for confirming this. I also need to get some AN fittings for hooking the Paxton FPR up. Are these parts that local stores should have?
Old Dec 26, 2001 | 01:50 PM
dustin's Avatar
Local stores probably do not carry them, but http://www.bakerprecision.com and http://www.anplumbing.com do (expensive though).
I have had very good experiences with the above two vendors.
Dustin
Old Dec 26, 2001 | 02:12 PM
New User
Do you know which fitting I would need to hook the fuel return line up to the FPR (which is AN -6)? I've figured out everything else but I'm not positive on this one. BTW, I'm using anplumbing.com
jakscivic
Jun 11, 2006 08:31 PM
JG90CRX-Si
Feb 3, 2005 06:28 PM
Cractos
May 2, 2004 06:11 PM
philly blunt
Apr 20, 2004 05:54 PM
HuGEN
Mar 5, 2002 04:25 AM
