idle problem d16z6
d16z6 in 94 dx
CEL
code 3. MAP sensor
code 19. auto tranny sensor. it's an auto P28 running a 5spd
code 21. VTEC solenoid
no other codes, which makes me WANT to rule out the IACV, although i havent had time to actually take it off and see. i cant find any vacuum leaks, and i tried replacing the map sensor but the 2 screws rounded as soon as i put a screwdriver on them.
*ALSO*
i reset my ECU and code 3 went away, but the idle problem is still there. when we did the swap my friend started messing around with the idle adj. screw. could this affect?
CEL
code 3. MAP sensor
*ALSO*
https://honda-tech.com/zerothread?id=1045101
Buy my turbo kit, I'll even give you a new map sensor
what exactly is the problem w/ idle? Is the VTEC wiring done? Go ahead & remove the Auto components if you can, at least get rid of that...
http://www.pgmfi.org
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">what exactly is the problem w/ idle? Is the VTEC wiring done? Go ahead & remove the Auto components if you can, at least get rid of that...
the idle jumps between 1000 and 1500 rpm. could the IACV be faulty and not throw a code?
and no...vtec isnt wired. i need the ECU pins
. i have a junk GSR harness that i'm using for the rest of the wiring
it's already a 5spd if that's what you mean by removing the auto components. i just have the ECU from the auto that it came from
anyone else?
. i have a junk GSR harness that i'm using for the rest of the wiringit's already a 5spd if that's what you mean by removing the auto components. i just have the ECU from the auto that it came from
anyone else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinhonda94 »</TD></TR><TR><TD CLASS="quote">im also having a problem with my idle.my engine is stock but i have a headder and full exzoust . any thing i can chek, just does when im at idle </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1010768
read it.
read it.
bump.
just realized that the problem STARTED when i put a honda (paper) throttle body gasket on. are these known to cause vacuum leaks?
project91crxsi
16
Jun 2, 2011 08:30 AM
1991civicd16z6
13
Jan 20, 2008 09:43 AM
exploder101
Apr 24, 2005 08:36 PM
