Blinkers no worky
Old Nov 13, 2004 | 09:41 AM
Ricta's Avatar
Default Blinkers no worky
Yeah my blinkers dont work anymore but my hazards work i think i blew a fuse but i dont know where the fuse for my blinkers is located help please TY
Old Nov 13, 2004 | 10:26 AM
Ricta's Avatar
Default Re: Blinkers no worky (Ricta)
B U M P
Old Nov 13, 2004 | 10:29 AM
Deemeetree's Avatar
Electrician
Check your fuse panel under your dash. The panel you pull off has a diagram of which is which. If it's not there, there's another fuse box under your hood in front of the battery that also has the diagram.
Old Nov 13, 2004 | 11:08 AM
Ricta's Avatar
Default Re: (Dimi)
Yeah i checked both and my dash box has no diagram and my hood box dose but i dont know what one to fool around with. So like what fuse would cause my blinkers not to work but my hazards to work. Thanks for help
Old Nov 14, 2004 | 09:06 AM
Ricta's Avatar
Default Re: (Ricta)
b U M P
Old Nov 14, 2004 | 10:25 AM
f1z1c's Avatar
Default Re: (Ricta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricta &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i checked both and my dash box has no diagram and my hood box dose but i dont know what one to fool around with. So like what fuse would cause my blinkers not to work but my hazards to work. Thanks for help </TD></TR></TABLE>
check the lights are not burnt out.
Dont fool around with the fuses, go to Kragen and get a buss fuse tester and check them all.
If its not the fuse, replace the relay. (Under dash)
Maybe the switch 2.
Use hand signals to avoid loss of limb in the meantime.
Old Nov 14, 2004 | 11:15 AM
pdiggitydogg's Avatar
its one of the fuses under the dash - Im positive
https://honda-tech.com/zerothread?id=910218
https://honda-tech.com/zerothread?id=730506
Old Nov 15, 2004 | 08:59 AM
Ricta's Avatar
Default Re: (pdiggitydogg)
Turns out i needed to replace the Blinker switch thanks for the help guys.
EgHatchy96
Aug 26, 2013 12:27 AM
ahloung
12
Mar 16, 2006 08:00 PM
bgmat58
Jan 5, 2005 08:44 PM
Jmorin
Sep 24, 2003 09:55 AM
