Crankshaft Timing gear thingy question...
Old Nov 13, 2004 | 03:36 AM
aut0tek's Avatar
Default Crankshaft Timing gear thingy question...
(edit: LS BLOCK)
Okay, so I finally get the engine running and I notice that the timing belt is rubbing on something... it's somewhere on the block, possibly the water pump housing??? The belt slid on the gear sideways and got closer and closer to the edge of the cam gears/h2o pump gears, etc... But when it's like that, it's rubbing on something in there... what do I need to do in order to fix this? the only thing I can think of is that somehow the gear on the crankshaft that the timing belt goes around on the bottom is pushed in too close to the oil pump... is there a way to fix that? The little circle thingies are in there and everything. (They were a little rusty, but I don't think it'll matter, will it?
Anyhow, if anybody knows the correct way to put that gear on, maybe has a picture or something (LS block) let me know... much appreciated.
Ratliff
Old Nov 13, 2004 | 06:10 AM
b18cls1's Avatar
Default Re: Crankshaft Timing gear thingy question... (aut0tek)
the 2 guides that go arround the crank gear at the oil pump are what keeps the belt centered
Old Nov 13, 2004 | 02:24 PM
aut0tek's Avatar
Default Re: Crankshaft Timing gear thingy question... (b18cls1)
right... and the'yre on properly... so why is the belt rubbing on the block? maybe the crank gear isn't installed properly?
Ratliff
jminthemachine
Oct 27, 2015 05:52 AM
meuby
Mar 6, 2011 05:58 PM
central_driver
Jan 12, 2009 07:05 PM
SuperSteve737
Apr 4, 2006 03:33 PM
EGTeK
Aug 3, 2003 01:37 PM
