My wont my R start right away?
Old Dec 26, 2001 | 08:52 AM
JSpecwest's Avatar
New User
Default Why wont my R start right away?
After I have not driven my R for awhile and get in to start it, it wont turn over. It just clicks like a dead battery. Ill turn the key 10-12 times before the motor will turn over and start. Bad starter? Also, I just put my rebuilt motor in. Does a new motor require more oil than usual, or burn oil during the break in process? Thanks...
[Modified by JSpecwest, 7:26 PM 12/26/2001]
Old Dec 26, 2001 | 09:09 AM
Spade's Avatar
Default Re: My wont my R start right away? (JSpecwest)
Have you had the battery tested? Sounds like that to me as well. The new motors require sesitive driving and oil changes but the volume of oil required is the same as stock.
Old Dec 26, 2001 | 09:10 AM
rainforest's Avatar
get a charger test/battery test. you can take it to like to your local garage and they will have a battery/altenator tester. or if you have a mltimeter you can test your battery by putting the negative on the negative terminal of the battery and the pos on pos and it should read 12.1-9 volts. you could also do a teat the starter by doing a voltage drop test. check the alternator and the alternator belt tension also.
Old Dec 26, 2001 | 09:31 AM
chi1874436's Avatar
Yep! A rebuilt motor will continue to burn oil for a few thousand miles. I would do all of the above and also continue to check my oil level often. Your motor burns oil like hell during the break in process.
Old Dec 26, 2001 | 09:34 AM
JSpecwest's Avatar
New User
Default Re: My wont my R start right away? (chi1874436)
How easy is it to have a ring not set properly?
Spade's Avatar
If you rev that thing......EASY.
Old Dec 26, 2001 | 09:39 AM
Big James's Avatar
New User
I don't think it is the battery. It could be a bad relay or your starter. If it was the battery, it would not be acting like it is.
Old Dec 26, 2001 | 09:43 AM
Spade's Avatar
Default Re: My wont my R start right away? (Big James)
Easy stuff first.....check the battery and if it isn't then we go to the relays!!!
Old Dec 26, 2001 | 09:45 AM
JSpecwest's Avatar
New User
I drove it the first 2 weeks on 4 1/2 quarts of oil. The other day VTEC would not engage. I thought WTF?? My buddy came over and it wasnt too long before we figured out I was really low on oil!! Put 3 quarts back in and VTEC is back.
Old Dec 26, 2001 | 09:49 AM
Spade's Avatar
during the break in period you need to monitor the oil on almost a daily basis and you do NOT use synthetic.
Old Dec 26, 2001 | 10:14 AM
JSpecwest's Avatar
New User
Default Re: My wont my R start right away? (Spade)
Ok good. Thought my rings didnt set properly.
Old Dec 26, 2001 | 11:46 AM
Greyout's Avatar
in that case you would have trails of smoke in your exhaust probably.... next time you drain your oil, look for fuel in the oil. (I think it floats, right?)
Old Dec 27, 2001 | 03:09 PM
rioninja's Avatar
Default Re: Why wont my R start right away? (JSpecwest)
Check all the motor grounds. If you just have the valve cover ground, you will get these kinds of symptoms. The battery will act dead, but the car will seem to have full power. Try adding another ground from the tranny to the chasis and see if this fixes the problem.
Old Dec 27, 2001 | 04:19 PM
976's Avatar
976
New User
Default Re: Why wont my R start right away? (RioNinja)
There is three motor-related ground, right? Then battery ground...
Old Dec 27, 2001 | 11:54 PM
DarthLuder's Avatar
New User
JSpecwest maybe u disconnected the battery and forgot too tighten the screw back. My R had the same problem u described. Most likely you just forgot to tighten it. Thats what happened to me.
[Modified by O0oToOKo0Oo0OR555, 8:56 AM 12/28/2001]
Lmgrcivic
10
Jan 9, 2006 04:50 AM
flatblk
Jun 9, 2005 09:41 PM
slowboy
Apr 6, 2003 08:41 AM
JSpecwest
Dec 26, 2001 09:47 AM
