Honda S2000 Honda S2000
A question for those with Force Induction
Old Dec 26, 2001 | 08:37 AM
vwandhondaboy's Avatar
Default A question for those with Force Induction
With force induction you can't have alot of valve overlap right?
If you do you loose alot of boost through the exhaust system.
But the fun cam lobes of a V-Tech engine have $h!t load of overlap.
So then how do you turboed guys compensate for that?
Do you dial out the valve overlap with adjustable cams gears?
Please do tell, spread the
Old Dec 27, 2001 | 09:06 PM
TrustGs-R's Avatar
New User
Default Re: A question for those with Force Induction (vwandhondaboy)
not really sure if you were looking for a non-s2000/non-nsx owner to reply...
but i DO daily drive/own/tune a viper eating turbo gsr if you wanna hear my thoughts...
so, yes. Tuning out overlap with cam gears definitely does good things for keeping boost in, while in VTEC. You can also disable VTEC if you like, but be aware that VTEC also causes a massive fuel dump...don't be caught at max boost running lean all because you wanted to try turning off VTEC without adding fuel up top.
good luck
Old Dec 28, 2001 | 01:19 AM
redteg1's Avatar
Default Re: A question for those with Force Induction (TrustGs-R)
whoaa....wat kinda of turbo do u have? wats your setup? how many lbs boost? VIPER EATING?! thats gotta be craazzy.
Old Dec 28, 2001 | 03:04 PM
TrustGs-R's Avatar
New User
Default Re: A question for those with Force Induction (redteg1)
drag 3 @16psi with another 8K of goodies
Civic89stdB16
Jan 12, 2012 09:31 AM
kikoy
Apr 3, 2006 09:30 PM
Coldsi
May 22, 2002 11:17 AM
greengangsta
Jan 2, 2002 12:29 PM
vwandhondaboy
Dec 26, 2001 11:38 AM
