B18c ARP main bolt install?
Old Nov 12, 2004 | 08:51 PM
b18bVtecRS's Avatar
Default B18c ARP main bolt install?
Hi, I am doing a LS/Vtec and am using an Endyne block girdle. So I got the ARP B18c main bolts. My question is do i torque the studs down first, then put the caps on then torque the bolts. If so what are the specs? The instruction it the box said put the studs in hand tight, then torque the bolts to 70 pounds. That doesn't sound like enough to me, but if so let me know.
Old Nov 13, 2004 | 09:29 AM
mmuller's Avatar
Mad Scientist
Default Re: B18c ARP main bolt install? (b18bVtecRS)
go by what the directions say.
check clearances to see if you have to line bore
Old Nov 15, 2004 | 12:48 PM
JDMpianoguy's Avatar
Default Re: B18c ARP main bolt install? (mmuller)
Those directions are accurate. Make sure you always follows the ARP instruction or you could see some bad things happen...aka spun bearing.
Old Nov 15, 2004 | 07:07 PM
b18bVtecRS's Avatar
Default Re: B18c ARP main bolt install? (JDMpianoguy)
Thanks guys, I just thought they needed to be like some head studs and be torqued down 10 ftlbs. But I just followed ARPs instructions and hand tightened them.
LastGenEK
Aug 1, 2012 08:52 AM
civicgeek133
Nov 28, 2010 08:37 AM
Teamdiesel
Feb 28, 2008 10:52 AM
Pompiuses
Jun 12, 2007 05:40 PM
the.hamburglar
Feb 17, 2006 06:48 AM
