Rounded a bolt and then some...help
Old Nov 12, 2004 | 06:28 PM
trickmaster505's Avatar
Default Rounded a bolt and then some...help
OK... today i rounded a bolt on my lower rear control arm, but decided that wasn't good enough. Dont ask me what I was thinking, but i put a grinder to it and now I have very little stud left so it is almost impossible to get leverage on it. I was just wondering if anyone knew how I should go about getting what is left of my bolt out. If suggested that I should take it in, I'd like to know a place that could do it, and how much do u think it should cost.
Modified by trickmaster505 at 5:48 PM 11/13/2004
Old Nov 12, 2004 | 06:47 PM
iBear's Avatar
Default Re: Rounded a bolt and then some...help (trickmaster505)
damn that sucks man, i had the same thing happen to me. It's a real bitch and you can't really do anything about it now. Take it to a shop and see if they can do it for you. It shouldn't be more than 10 dollars (for me at least).
Old Nov 12, 2004 | 07:14 PM
JET_dC4's Avatar
they can probably weld a stud on to it in order to get enough tourque on it.
Old Nov 12, 2004 | 07:17 PM
x00gsr's Avatar
Having same problem, just gave up, but there are many tools capable of taking out the stud. I'm looking into this item right here.
http://www.mytoolstore.com/kd/kdspec06.html
Old Nov 12, 2004 | 07:35 PM
WhiteGSR95's Avatar
get one of those air gun sockets. find 1 thats almost the same size and hammer that bitch in then screw it out.
Old Nov 12, 2004 | 08:13 PM
comteg396's Avatar
get a bolt extracting kit from sears or other auto store. if i remeber right, it drill into the bolt itself and it using the reverse on a drill to extract it
Old Nov 12, 2004 | 10:34 PM
boosted k20's Avatar
Default Re: Rounded a bolt and then some...help (s0n1c b1u3)
when that happens to me, i just weld another bolt onto the stripped bolt and unscrew it from that. works all the time
Old Nov 12, 2004 | 11:39 PM
Slain's Avatar
extractor kit works wonders..
Old Nov 13, 2004 | 12:40 AM
Sack Master's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">extractor kit works wonders..</TD></TR></TABLE>
I will attest to that. Especially since I've been known to work on fords, they come in very handy.
Old Nov 13, 2004 | 12:46 AM
DopeSilver_97's Avatar
Default Re: (Sack Master)
the bolt extractor works wonders... also, try to use 6-point sockets that are the right size. rounding bolts usually is beucase of people using 12-points. i know from personnal experience.
Old Nov 13, 2004 | 06:11 AM
AllmansDB8*'s Avatar
You could use a bolt extractor to try to get the bolt out. But the bolt might still
just spin in side the metal sleeve in the bushing.
If it does spin, then your best bet is to cut the bolts off on both ends with a cut off wheel.
Take the lower control arm off, press the bushing out and replace the bushing.
Put new bolts in and your good...
thekidsnitty
Suspension & Brakes
Jul 2, 2012 05:57 PM
vteck1ck
14
Nov 14, 2008 08:55 PM
92civicx
10
Nov 3, 2008 03:14 PM
LsNer00
Jun 29, 2004 12:09 PM
fubar
Jul 19, 2002 09:19 AM
