ARE AIR/FUEL RATIO GAUGES REALY ACCURATE?
Old Nov 12, 2004 | 06:00 PM
one slow eg5's Avatar
Default ARE AIR/FUEL RATIO GAUGES REALY ACCURATE?
I installed one but i do think im getting the right reading and im not going to lean it out just based on this gauge. The gauge reads 2-3 greens lights when idol, then 3-4 greens when wop. Is this right or is my o2 sensor done??? The guage dosnt pulse at all like i hear it should do. I go instructions but jsut wanted to know what you guys think?
thanks
jeff
Old Nov 12, 2004 | 06:01 PM
BeavisB16's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (one slow eg5)
from what I have read (i dont have one) they are NOT accurate.
Old Nov 12, 2004 | 06:09 PM
Turbogixxer's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (BeavisB16)
It is using your narrowband 02. That means it only tells you if it is rich or lean. They are nothing to try to tune with.
Old Nov 12, 2004 | 06:17 PM
hondainspired's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (turbogixxer)
yea ... there jus another flashing LED .... IMO... unless you have a what i thought was called a "Wideband O2" meter ... for acurate tuning...
Old Nov 12, 2004 | 06:23 PM
SkRiBLaH's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (hondainspired)
with your stock o2 sensor, it might as well be a light bulb. because thats all it reads, on or off. it only reads rich, or not rich. there is no inbetween..
Old Nov 12, 2004 | 08:19 PM
endlesswinterco's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (SkRiBLaH)
its a great light show, thats about it. get an egt guage and a five wire o2 with a/f ratio if you wnat somthing to work.
Old Nov 12, 2004 | 08:22 PM
huntarrr's Avatar
its just flashing lights and nothing more.
Old Nov 12, 2004 | 08:25 PM
hondaeg8's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (vsm98civic)
ha....mine stays in the green when i'm driving and when i start to slow down to come to a complete stop, it goes to the red section. don't go by what this type of guage reads.
Old Nov 12, 2004 | 08:28 PM
PRcivicHB's Avatar
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">ha....mine stays in the green when i'm driving and when i start to slow down to come to a complete stop, it goes to the red section. don't go by what this type of guage reads. </TD></TR></TABLE>
its suppose to do that because you let off the gas....
Old Nov 12, 2004 | 10:20 PM
Default Re: ARE AIR/FUEL RATIO GAUGES REALY ACCURATE? (PRcivicHB)
OK mine duz the same thing. So basicaly go buy the aem $1,000 egt? lol
thanks.
Anyone need a used Air/Fuel gauge?
lol
jeff
Old Nov 12, 2004 | 10:22 PM
B16Drag's Avatar
why dont u just get a wideband for $300?
A/F guage is pretty much worthless.
Old Nov 13, 2004 | 07:58 AM
00supercivic's Avatar
Default Re: (B16Drag)
first make sure you have your purple wire from the guage hooked up to the right wire off the O2 sensor. it should be the white wire or signal high wire. i don't know what your car has OBD 1 or OBD 2 but it should be hooked up on the first O2 sensor that the exhuast gasses will hit first in this case it should be on the header.
Old Nov 13, 2004 | 08:09 AM
Ricey McRicerton's Avatar
Default Re: (00supercivic)
Without a wideband, you may be able to watch what is happening in the small area that your stock 02 sensor reads (0-1v) but a wideband reads 5 times that (0-5v).
Old Nov 13, 2004 | 08:46 AM
mildly.interesting's Avatar
not accurate like a wideband is...
Old Nov 13, 2004 | 10:07 AM
Default Re: (mildly interesting)
but then without decent mods and some dyno tyme.. wideband still isn't really even needed
Old Nov 13, 2004 | 10:58 AM
Default Re: (hondainspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">but then without decent mods and some dyno tyme.. wideband still isn't really even needed</TD></TR></TABLE>
Why is that? explain.
Old Nov 13, 2004 | 11:02 AM
Br1anPham's Avatar
Default Re: (turbogixxer)
i love my zeitronics wideband
Accurate? Im pretty sure it is!
Old Nov 13, 2004 | 12:18 PM
Frozen E's Avatar
H-T White Ops
PLX M-500
As far as the A/F lightshow you have....I wouldn't bet MY motor on that.
peddyeye
Dec 1, 2008 01:52 AM
brad98prelude
Dec 28, 2005 04:17 PM
teler86
Jun 30, 2005 03:55 AM
doublejz
Jan 14, 2004 05:31 AM
HX_Guy
Aug 30, 2001 07:31 AM
