Torqueing without spinning crank
Old Nov 12, 2004 | 04:58 PM
smash fascism's Avatar
Default Torqueing without spinning crank
I am going to replace the flywheel on my motor along with the crank pulley. I would like to know how to pin the engine from turning over while torqueing the flywheel bolts and crank pulley bolts to spec. I don't want to use the flywheel teeth, because I don't want to damage them.
Thanks
Old Nov 12, 2004 | 05:04 PM
86si's Avatar
Default Re: Torqueing without spinning crank (smash fascism)
they sell a tool to lock the crank pulley or put the car in gear and have someone apply the brakes(I get my wife to do it) while you tq. the bolts
Old Nov 12, 2004 | 05:07 PM
incredteg3's Avatar
Default Re: Torqueing without spinning crank (86si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">they sell a tool to lock the crank pulley or put the car in gear and have someone apply the brakes(I get my wife to do it) while you tq. the bolts </TD></TR></TABLE>
yea fith gear (longer)
Old Nov 12, 2004 | 05:15 PM
What if the motors out of the car? I am going to do this stuff over the winter while the motors on an engine stand.
Thanks
Old Nov 12, 2004 | 05:19 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si &raquo;</TD></TR><TR><TD CLASS="quote">put the car in gear and have someone apply the brakes </TD></TR></TABLE>
With the transmission out of the car??
You won't damage the flywheel teeth, they are extremely hard to stand up to the beating of the starter every time you crank it. I spose you could get a breaker bar on the crank pulley bolt, or if you're a redneck, stuff a rope in a cylinder.
Old Nov 12, 2004 | 08:05 PM
incredteg3's Avatar
Default Re: Torqueing without spinning crank (drdisco69)
i dono if this will help but here it goes. if you have a welder you can take a garbage fly wheel cut a section off and make it so that you can bolt it to the block where your tranny normally bolts to it. there are probably better ways this is just what i have used before
Old Nov 12, 2004 | 08:40 PM
00000xxx's Avatar
Default Re: Torqueing without spinning crank (incredteg3)
the teeth on flywheels are serious ... and your only applying 76 lbs of torque compared to what the starter produces... if your flywheel teeth break or warp from a screwdriver or flatbar then your flywheel is weak
yeah the tranny is going to be off the motor for the flywheel but when your done with the flywheel and the tranny is back up then put the tranny in gear and proceed with pulling the crankpulley off or just get the key.. which is much better
PreludePhill
Sep 9, 2007 11:06 PM
kr
Oct 22, 2005 04:01 PM
Civicman86
Oct 7, 2005 01:29 PM
Dan GSR
Apr 4, 2005 04:29 AM
Silude
Jun 6, 2001 07:24 PM
