Problem Adjusting timing
Old Nov 12, 2004 | 04:18 PM
DrewDown's Avatar
Default Problem Adjusting timing
I just bought a brand new distributor from Diststributor King and recieved it today. I put it on my 1993 Integra LS and the car started right up. So I went to adjust the timing and jumpered the two wires on the passenger side under the dash, and adusted the timing with a timing light.
I ran into a problem adjusting the timing. When I adjust the distributer clockwise it starts getting closer to where it needs to be, but now it is maxed out and I can not adjust it any more. Now what should I do. I am sure that all the plug wires are correct. Also when I take off the cap the rotor is pointed to the #1 cylinder when the motor is at top dead center.
Old Nov 12, 2004 | 04:31 PM
86si's Avatar
Default Re: Problem Adjusting timing (DrewDown)
I've ran into this problem with aftermarket distributors.It will only adjust to about 12 degrees.Get one from Honda the quality is much better anyway.
Old Nov 12, 2004 | 04:38 PM
drdisco69's Avatar
Your timing might be off at the belt. Could be just the intake cam, or both.
Old Nov 12, 2004 | 04:48 PM
DrewDown's Avatar
so I might be screwed out of 200 bucks. How can I tell if the timing is off at the intake cam?
Old Nov 12, 2004 | 04:54 PM
86si's Avatar
Default Re: (DrewDown)
i'm assuming you replaced the dist. because it siezed or the coil or ignitor took a ****.How did it run prior to replacing it?If it ran good than your mechanical timing is fine,but if you really want to check it you'll have to remove the valve cover and line up your timing marks.But like I said before aftermarket dist. are junk!
Old Nov 12, 2004 | 04:57 PM
DrewDown's Avatar
Yes the car ran fine before distributor took a dump on me. The cap and rotor were both messed up, also there is a little gear inside that all the teeth were busted up and chewed off. Plus the shaft that the distributor cap mounts on had lots of play in it.
Couldnt I always just dremel out the holes to give it more adjustment?
Old Nov 12, 2004 | 04:59 PM
86si's Avatar
I never really thought of doing that,if you can return it I would if not give it a shot.
Old Nov 12, 2004 | 06:12 PM
DrewDown's Avatar
Well I guess I will call Distributor King tomorrow or Monday if they are not open tomorrow. Do you think it is a bad idea to drive the car right now? It bogs down low and feel gutless, but starts and idles fine. Could I cause any damage? I'm assuming it's retarded and not advanced.
Old Nov 13, 2004 | 04:15 AM
86si's Avatar
it won't cause any damage it will just be sluggish.
Old Nov 13, 2004 | 08:35 AM
mmuller's Avatar
Mad Scientist
just grind away the mounting holes on the dizzy so you can adjust some more
Old Nov 13, 2004 | 10:56 AM
DrewDown's Avatar
Default Re: Problem Adjusting timing (mmuller)
Damn distributor king is not open today so I don't know if I should grind out the holes or wait until Monday.
zx92027xz
Aug 11, 2012 06:47 AM
ef_hopeful
Jan 28, 2008 07:10 PM
5thgencivicr
Jun 25, 2005 10:58 PM
fufu
Sep 19, 2004 04:21 PM
Hybridize
Oct 31, 2003 11:31 AM
