cylinder sleeves for a D16Y8
Hey guys,
I confess I'm a little lost on the topic of cylinder sleeves for my civic.
When are they neccesary?
What exactly are they?
I've heards several different things about them ranging from inserts to full on replacement cylinders that yoy drop in.
If any one can lend some advice or links I'd appreciate it
Theres 2 types of Cylinder sleeves.
1 is the replacement inserts, which are used on stock rebuilds. Common for your basic every day use engine.
the other type is what is usually talked about in racing which is the Iron ductile Thick sleeves. These are not inserts for the stock cylinders. The process cuts the actual stock cylinders about half way and the Iron Ductile Sleeves are pressed in to fit.
I have posted comparison pics several times, let me look for the pictures I posted up to show the difference of a stock vs SLeeved block.
Pictures -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">This question comes up so many times, I've cut and pasted what I have posted on another thread.
Look at the first pic, thats a stock sleeved B18
VS
A sleeved block with a whole new Iron Ductile Sleeve pressed in
VS
chrisir19
Jun 20, 2002 09:09 AM
