Civic won't start, little help
Old Nov 12, 2004 | 09:05 AM
AKprelude's Avatar
Default Civic won't start, little help
2000 Honda Civic DX SOHC
I changed the spark plugs yesterday. After I was done, fired up the car and it started fine and ran for about ten seconds then I turned it off. Later that night I went to go drive it and it wouldn't start. The starter is cranking, it just won't turn over. I checked the battery, 12.5 volts. I even tried to jump it with the prelude, still wouldn't start. The fuel filter is new (last month), so it should be getting enough fuel. Maybe the plugs arn't firing? But it started the one time......
Any ideas?
Old Nov 12, 2004 | 01:13 PM
AKprelude's Avatar
Default Re: Civic won't start, little help (AKprelude)
Nothing?
Old Nov 12, 2004 | 01:15 PM
ososlow24's Avatar
From: Over Ten Thousand HONDA CIVIC Lakes, MINNESOTA
check your distributer, might be the coil
Old Nov 12, 2004 | 01:40 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AKprelude &raquo;</TD></TR><TR><TD CLASS="quote">The starter is cranking, it just won't turn over.</TD></TR></TABLE>
Check to see if you are getting spark.
Remove a plug from the head, put it back onto the wire, hold the ground electrode against a piece of bare metal in your engine bay (like a valve cover nut) and have someone crank the engine while you look for the spark. Make sure you hold it by the wire or something so you don't get zapped.
What plugs did you buy? You didn't change the wires or anything else, did you?
Old Nov 12, 2004 | 02:00 PM
TheIntegraGuy's Avatar
Also, check your ignitor as well. I would say that the ignitor is probably the problem.
Old Nov 12, 2004 | 02:24 PM
AKprelude's Avatar
Default Re: (TheIntegraGuy)
I bought standard autolights, checked the gap before installing. Didn't replace any of the wires or anything.
Will check the distributer tonight.
Where is the ignitor?
ef9_pr0jekt
Mar 7, 2020 07:44 AM
Marla Lee
Honda Civic (2006 - 2015)
Feb 25, 2017 09:35 PM
wheelchair
Sep 24, 2015 08:24 PM
ej2civic
11
Mar 5, 2007 12:40 PM
nfiedler3
Aug 13, 2005 11:35 PM
