code 71,72,73, and 74?
Old Nov 12, 2004 | 06:50 AM
jeffsciv23's Avatar
Default code 71,72,73, and 74?
i have a 99 ex and i keep on gettig these codes. they are for misfiring in the cylinders. i just adjusted my timing and it went away but then it came back, what could be causing it? could my timing belt be going?
Old Nov 12, 2004 | 08:27 AM
Slow98sedan's Avatar
Default Re: code 71,72,73, and 74? (jeffsciv23)
What condition are your spark plugs in?
Maybe that would be part of the problem?
..adam..
Old Nov 12, 2004 | 09:01 AM
Andres-eh2's Avatar
Default Re: code 71,72,73, and 74? (Slow98sedan)
did you change the wires recently and screw up the firing order?
Old Nov 12, 2004 | 09:38 AM
jeffsciv23's Avatar
Default Re: code 71,72,73, and 74? (Andres-eh2)
i haven't messed with the plug wires anytime recently. maybe i'll try new plugs before i go changing the timing belt.
Old Nov 12, 2004 | 09:52 AM
EE_Chris's Avatar
Is this a bone stock 99 Ex?
Have a turbo kit - maybe the GReddy kit with the bluebox?
Old Nov 12, 2004 | 10:05 AM
jeffsciv23's Avatar
Default Re: code 71,72,73, and 74? (EE_Chris)
it had a t-25 but i sold that kit and pieced together a kit with a t3. not the bluebox but i am running a Vafc hack.
Old Nov 12, 2004 | 10:09 AM
EE_Chris's Avatar
What is your base timing set to? Did you verify it with a timing light?
Did you run the Hack on the old T25 setup? Did you have the same misfire problems?
CivicSmith
42
Jul 8, 2014 12:54 PM
coolswimmerjon
Sep 3, 2011 07:43 AM
toolboxtony
Jul 18, 2011 03:23 PM
sleepyhamsterlx
Jul 3, 2006 07:19 AM
foreverjenn
Sep 28, 2002 09:06 AM
