i got some Questions on A Ls Vtec...
i got a B16 head and it came with Gsr cams.. wat timing belt do i put in?
Can I use the Gsr Cams theres no problem?
Wat head gasket do i put?
Can i use a Ls Distributer?
the Ls is 99 OBD2 But the car/harness is OBD0.....
Wat ecu do i buy and do they sell a piky back for it?
Thx....
Please tell me all the informatoin u can give me I need some help....
Thx....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM91DA »</TD></TR><TR><TD CLASS="quote">i got a B16 head and it came with Gsr cams.. wat timing belt do i put in?
Thx....
you can use any b series vtec cams
you match the timing belt with the water pump gsr/itr timing belt for 22t water pump and ls timing belt for 19 tooth water pump
you use a stock ls head gasket for lsvtec
you can only use the ls dizzy if you cut 1 leg off
Thx....
boosted92hatch
May 29, 2006 08:44 AM
