Valve cover modification?
Old Nov 11, 2004 | 06:15 PM
cal_'s Avatar
Default Valve cover modification?
So i was at the track the other day and i was looking at a honda civic that was allmotor and noticed that there was some tubes coming off the valve cover that went into the exhaust system. My friend that was there with me said it was to help releive the pressure that built up in the head and there for you gained more hp. Is there any truth to this cause if there is why dont i see more of it?
Old Nov 11, 2004 | 06:27 PM
drdisco69's Avatar
Default Re: Valve cover modification? (gsr778)
Tis true. The exhaust creates a vaccuum in the motor, helping to seal the rings and reduce windage losses. You don't see it more because it's not exactly emissions friendly, pulling oil vapor into the exhaust. I'm sure plenty of posts will follow calling me full of ****, or spreading bs, so lets have it.
Old Nov 11, 2004 | 06:49 PM
VdubLuv82's Avatar
Default Re: Valve cover modification? (drdisco69)
on honda isn't there one that goes into the intake?
Old Nov 11, 2004 | 06:52 PM
cal_'s Avatar
Default Re: Valve cover modification? (VdubLuv82)
there is but it mostly just get all sort of carbon and junk up into the intake.
Old Nov 11, 2004 | 06:56 PM
drdisco69's Avatar
The one that goes to the intake doesn't create the kind of vaccuum the exhaust types do. You can actually have problems sealing the motor from air getting in with those systems, instead of oil getting out.
Old Nov 11, 2004 | 07:07 PM
eda6's Avatar
So is it a bad idea put a breather filter on the valve cover and cap off that port on the intake?
Old Nov 17, 2004 | 04:22 PM
Mr. B in Az's Avatar
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
Default Re: Valve cover modification? (eda6)
more discussion on these threads.......
https://honda-tech.com/zerothread?id=1018442
http://www.team-integra.net/fo...sp#14
but the big v8 drag cars run vacuum on their blocks via lines coming from their valve covers to their exhaust.
Old Nov 17, 2004 | 04:43 PM
drdisco69's Avatar
Default Re: Valve cover modification? (Mr. B in Az)
Man, that team-integra thing is flat WRONG.
Old Nov 17, 2004 | 04:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Man, that team-integra thing is flat WRONG.</TD></TR></TABLE>
Agreed.......I wasn't saying it was correct......just more discussion.
I put up the link for the pic that it contained.
Old Nov 17, 2004 | 05:02 PM
drdisco69's Avatar
, just as long as people know...
Old Nov 17, 2004 | 06:39 PM
Arsenal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">So is it a bad idea put a breather filter on the valve cover and cap off that port on the intake?
Old Nov 17, 2004 | 06:47 PM
drdisco69's Avatar
Default Re: Valve cover modification? (Arsenal)
Yes.
Old Nov 17, 2004 | 07:17 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
yep im with drdisco69; the v8 boys have been doing this for loooong long years.
they sell kits at summit.
the fittings go into the exhaust at a certain angle(cant remember what), creating vaccum
Old Nov 17, 2004 | 07:25 PM
drdisco69's Avatar
Default Re: Valve cover modification? (mmuller)
45* with the end of the tube cut parallel to the exhaust flow.
http://www.moroso.com/catalog/...13023
Look at the instructions.
krazy_23
Engine Machining & Assembly
Dec 6, 2015 06:20 PM
dohdoh420
Welding / Fabrication
Aug 18, 2011 09:08 AM
LSVTEC 91 Civic
Jul 30, 2005 12:47 PM
jdmjopey
Aug 31, 2004 09:54 PM
vicz
Apr 13, 2003 06:24 AM
